Author Topic: aftermarket gauge panel mounting ideas?  (Read 3731 times)
Offline shadango
« on: May 16, 2009 - 07:44:38 AM »
What I thought would be a no brainer isnt ...LOL
Wanted to get a 3-gauge panel from summit ----mechanical oil, water temp and volts -- so I know whats going on under the hood when I fire her up the first time.....well, the vent knobs are located under the ash tray where I figured I could mount it.....under the radio bezel seems too close to the top of your leg.....
I was thinking I might be able to move the vent knobsto the left and right enough to clear a space.
I know most folks here seem to like using in dash gauges, but does anyone have a 3-gauge panel installed and have pics they can share?
What about tach mounting options?
Offline matt63
Re: aftermarket gauge panel mounting ideas?
« Reply #1 on: May 16, 2009 - 10:04:36 AM »
I made a bracket that mounts under the vent knobs using spacers.  Three Autometer pods were bolted to the bracket.  These are better than the Autometer 3 hole brackets as the pods can be turned so you can see the gauges properly.
Matt in Edmonton
'68 Valiant
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: May 16, 2009 - 10:15:46 AM »
I mounted the small autometer tach to a factory screw hole and put the 3 hole guage under the radio, never noticed it too close to my leg.
I need to try and find some green bulbs for the guages next.
Tom
Tom
Offline shadango
« Reply #3 on: May 16, 2009 - 01:31:50 PM »
Tom...that pic is great!   My interior is black and I am looking at the same gauges! iTS LIKE SEEING INTO THE FUTURE! lol
Offline 422STROKER
« Reply #4 on: May 16, 2009 - 11:24:38 PM »
No sweat, let me know if you need anymore.
Tom :thumbsup:
Tom
Offline shadango
« Reply #5 on: May 17, 2009 - 12:37:32 AM »
Tom, is that the 2 1/16 size or the 2 5/8" size?
« Last Edit: May 17, 2009 - 07:24:44 AM by shadango »
Offline 422STROKER
« Reply #6 on: May 17, 2009 - 07:49:49 AM »
These are the 2 1/16 IIRC.  I think they were 20 bucks or something.  My wife got them for me.
Tom :burnout:
I left the factory gauges operational, except for the Amp gauge as I ran a bypass.
Tom
« Reply #7 on: May 17, 2009 - 07:51:07 AM »
Tom,
  I wish my car had come with that Ipod option.   :walkaway:
Offline shadango
« Reply #8 on: May 17, 2009 - 08:01:58 AM »
Tom :burnout:
SO that is the electrical oil pressure gauge and not the mechanical?  COuldnt seem to find the electrical type oil pressure gauge on summit.....which is better...mechanical or electrical?  I figured mechanical, aside from having a noil line running into the interior....hooking up the electrical is probably easier....is it as accurate?
What is 'IIRC" ??
Offline 422STROKER
« Reply #9 on: May 17, 2009 - 11:57:02 AM »
IIRC  If I recall correctly.
That is the mechanical aftermarket oil gauge and the wire is for the factory set up.
MEK, I paid about 150 for the stereo, came with the IPOD cable built in, and a remote.  I put the IPOD in the Ashtray.
Tom :2thumbs:
Tom
Offline shadango
« Reply #10 on: May 17, 2009 - 06:06:35 PM »
Tom :2thumbs:
Gotcha......where on the engine did you tie in for the mechanical gauge? DO they supply thecorrect fittings to screw into the block?  Got pics of that or did I miss it?
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #11 on: May 17, 2009 - 07:03:56 PM »
I have a set of Auto Meter gages installed where the factory gages once were. Fit perfect and looks great!!
                                                    Matt B.
Matt
Offline FBJJChallenger
« Reply #12 on: May 19, 2009 - 06:23:57 PM »
Matt,
Did you sand and paint your woodgrain? It looks great with the autometer gauges! I'm planning on getting those too, but never thought of using the factory dash. I was planning on getting the instrument cluster that XV sells, but if I could get aftermarket gauges in the old dash and save $450+ that would definitely be up my alley! Do you know if the Autometer 5" speedometer would fit in the dash? It appears that you kept the old one in? Thanks for any info!
James
« Reply #13 on: May 19, 2009 - 09:57:09 PM »
I really don't know about the speedometer. The gages were installed when I bought the car. I don't think it was too difficult a fit. They look pretty darn close to the factory originals. Wish I could be of more help. I wouldn't have thought of doing it that way, but I think it looks pretty good!! :2thumbs:
                                                  Matt B.
Matt
Offline 422STROKER
« Reply #14 on: May 20, 2009 - 02:22:28 PM »
I think Goody has the aftermarket Speedo in that spot.
Tom
Tom
