Fuel evaporation/leakage question?
Author Topic: Fuel evaporation/leakage question?  (Read 885 times)
Offline 67vertman
  • Member since 9-23-2005
« on: May 16, 2009 - 03:32:44 PM »
I have been playing with my carb this weekend. Carter 2 Brl on a stock 318.
After setting for four to seven days the carb float bowl runs dry.  So I decided to run some test.
First, I filled the float bowl and measured the level.  I let it sit for one hour and checked the level again and there was a measurable difference.
Next I plugged the fuel feed line, so I could see if the fuel was running back to the fuel pump.  Refilled and checked the level again and let it sit for another hour and again the level dropped.
There are only two places the fuel could go. Evaporating or leaking down the metering jets via the step-up rods.  I don’t think gas would evaporate that fast, so it has to be going down the metering jets.  Does any one have any idea how to fix that issue? Or is it something I will have to live with?
Should I pull the carb and run the test again to see where the fuel is leak to/from?
Or should I just chuck the whole setup and go to a four barrel manifold and Carb?
Re: Fuel evaporation/leakage question?
« Reply #1 on: May 16, 2009 - 11:33:12 PM »
pull the carb & check for an internal leak , it should not leak down
Offline femtnmax
« Reply #2 on: May 16, 2009 - 11:59:10 PM »
Maybe pull the carb and set it on a sheet of paper towel, refill the float bowl, and watch for wet towel.
I have also noticed over the last several years the fuel evaporated much faster than 10-20 years ago.   If I let my old truck sit for a week, the float bowls are about half full of fuel if your lucky.  To me this is fast evaporation.   I thought it was a leak or such, did all sorts of tests, and it comes down to evaporation in my case.
One problem with pulling the carb, it won't be sitting on top of a hot engine...the heat of coarse speeding up the evaporation.
I'm all for more torque and power, but I would also say if you toss your OEM carb your also giving up the factory set up that was designed to work together.   I notice the aluminum intake manifolds heat and cool quickly which does affect the drivability in cooler climates.   On my old ford V8 truck, the Edel RPM intake worked great, but it was so tempermental to drive in spring/fall I ended up selling the Edy and replacing it with a OEM cast iron intake with heat crossover.   I tried running it with the heat crossover blocked off, used an Edel O2 sensor to set the jetting...it ran well.  But then I tried it with the crossover open like it was from the factory...I runs GREAT...the fuel is definitely atomizing better.
So depending on where you live, give it some thought. :2cents:
Phil
Offline 67vertman
« Reply #3 on: May 17, 2009 - 12:20:46 AM »
Thanks Guys.
I am going to pull the carb off and check for leaks.  The car was cool when I did the test so heat is not an issue.
Offline solarguy
« Reply #4 on: May 18, 2009 - 11:16:38 AM »
Please post the results of your test, I'm interested in the outcome.  Thanks
Offline quagmire
  • Traction Impaired......
« Reply #5 on: May 18, 2009 - 12:26:09 PM »
Due to the ethanol content in most all fuels now, evaporation is a much bigger problem on older carb cars with vented fuel bowls.  In fact, winter blends are specifically made more volatile to vaporize easier.  Mine does it too, and it has zero leaks.
