Author Topic: SB oiling question  (Read 932 times)
Offline 1970-cuda340
SB oiling question
« on: May 16, 2009 - 10:27:45 PM »
How does the lifter valley on the drivers side get it's supply of oil? I have oil pressure on the passenger side lifter valley but none on the driver's side.
Robert
Re: SB oiling question
« Reply #1 on: May 16, 2009 - 10:30:23 PM »
cam bearing journals
« Reply #2 on: May 16, 2009 - 10:35:22 PM »
Any idea which cam bearing would cause it? I have oil to both rocker arms.
« Reply #3 on: May 16, 2009 - 10:39:08 PM »
Oops, I made the wrong remark. Sorry.  I miss read yer post. I was thinking rockers
Offline Changin Gears
« Reply #4 on: May 16, 2009 - 11:16:42 PM »
Is the block an ex-race block?  It's a common modification to block the oil going to the drivers side lifters.  This is done by blocking the oil crossover passage in the front of the block.  This can be done for solid lifter cams.
« Reply #5 on: May 16, 2009 - 11:38:58 PM »
the left gallery feeds from the #1 main at the front of the block
« Reply #6 on: May 17, 2009 - 09:08:11 PM »
Found it!!!!!! Pulled the engine out today,pulled the crank out, and found the front main bearing hole drilled and a set screw installed in the oil jacket. Now i got the fun of putting it all back together.  :working:
« Reply #7 on: May 17, 2009 - 10:26:22 PM »
Good deal....
Offline LAA66
« Reply #8 on: May 17, 2009 - 10:35:20 PM »
