Author Topic: 71 Challenger Convertible Top Bleeding  (Read 1048 times)
Offline daveh
« on: May 18, 2009 - 01:17:13 PM »
Hey guys,
I installed new convertible pump lines on my 71 Challenger and the top is going up and down but slowly. I can see that the lines aren't completly full. Air pockets move around when it goes up or down. How do I bleed the system? Should the lines be completly full with fluid? If I crack a nut to put more fluid in it begins to leak out, more like spew out. I've only been filling it with the top down should it be up? Any suggestions you have are appreciated.
Thanks Dave
Offline hotrod98
    • Maniac Musclecars
Re: 71 Challenger Convertible Top Bleeding
« Reply #1 on: May 18, 2009 - 11:08:56 PM »
They are basically self bleeding. Your pump may be weak.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline hebeegbz
« Reply #2 on: May 22, 2009 - 01:52:04 PM »
 This is a comon problem ,if all parts are good you dont need all the air out . if you pull the plug out and install a clear hose about 18 inches long and install the other end in a qt of fluid half full , run the top several times till it works smooth .also take your time not to heat the pump and trip a fuse. the reason for the half bottle is so when the pump burps air and fluid you dont over fill the bottle .ad more as needed . when done remove hose and run once more the pump should not be higher than the sight plug ,install plug and hit the road . as the last post mentioned if the pumps week it will by pass fluid and act like a  floor jack thats not tight it pumps but cant keep up ,you can see this in the lines when pumps working and the bubbles hardly move . :2cents:
thread gone in 60 seconds
