Lifter noise 318 Cui
Author Topic: Lifter noise 318 Cui  (Read 3474 times)
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« on: May 18, 2009 - 03:59:35 PM »
Hi Guys...
After 5 times i have startet my 70´ 318 engine it came up with what I think is a lifter noise from driver side top. Are there some adjustment opportunities.... I have startet the engine 5 times after its have stand in 5 years, the first times was there no noise.. It has new oil and filter
I have not have the car out for a spind yet..
Oil pressure 75psi at idle.
Hope you guys can help me on track..
Thanks...
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
Re: Lifter noise 318 Cui
« Reply #1 on: May 18, 2009 - 08:07:03 PM »
no adjustment
 check for a plug inserted up to the left side lifter bank above the crank
Offline Danishmopar
« Reply #2 on: May 19, 2009 - 04:45:53 AM »
Hi Chryco :o)
Can you explain more af that  :clueless:.. I have a bolt plugget in on left side over the crank..
Thanks  :thumbsup:
Offline 426HEMI
« Reply #3 on: May 19, 2009 - 06:37:48 AM »
The valve train in hydrolic lifter set up is not adjustable.  They are self adjusting so to speak.  Hope that helps some.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline Danishmopar
« Reply #4 on: May 19, 2009 - 08:26:17 AM »
Thanks Guys  :cheers:
I mean that Chryco write, with the plug inserted up to the left side lifter bank ?
Will it be possible to take the lifters up with a magnet...
Thanks guys  :thumbsup:
Offline Changin Gears
« Reply #5 on: May 19, 2009 - 08:38:15 AM »
I would run it for a while, get some heat into it.  It is common for lifters to make some noise after not running for long periods of time.
Offline Danishmopar
« Reply #6 on: May 19, 2009 - 12:04:17 PM »
Hi  :2thumbs:
I startet it up again today and took her out for a littel spind. And it sounds better. I will chance the oil and filter again, and see how "she" runs after...
Thanks Guys..
« Reply #7 on: May 19, 2009 - 12:16:03 PM »
yes lifters can be changed without removing the intake using a magnet if nessisary
 I hope everything is OK
Offline 426HEMI
« Reply #8 on: May 19, 2009 - 02:19:06 PM »
Small blocks do not like to site very long.  Lifters will colapse at times when they site.  Some times it is hard to get the oil back into them but it should be ok.  Hope it does ok.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline JayBee
« Reply #9 on: May 19, 2009 - 07:22:39 PM »
This may be way out in left field but are you sure it's a lifter? I had a noise coming from the left side of my 318 once and swore it was a bad lifter. The noise turned out to be an exhaust leak that went away after I re-torqued the bolts.   :2cents:
John
1970 Barracuda convertible
2014 Toyota Avalon
« Reply #10 on: May 19, 2009 - 07:26:10 PM »
Great point. Even with a big block I was fooled once. A leak between the header flange and the heads sounded like a valve train problem to me at first too.    :banghead:
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #11 on: May 20, 2009 - 10:13:48 AM »
I have done this with Neils guidance, changed all the lifters....?  Never dawned on me that I might have a bad exhaust gasket!  I bought good exhaust gaskets and havent looked back since.
Don
Member Since January 14, 2002
Offline Danishmopar
« Reply #12 on: May 20, 2009 - 04:06:42 PM »
HI guys..
Thanks for all that respons  :2thumbs:
Ï have changed the oil and filter and tightened the headders... And now she runs like a pussycat, It reallý helps.
So can i always change the lifters in the winter months...
Thanks Guys
 :cheers:
Offline dodge freak 2
« Reply #13 on: May 20, 2009 - 10:07:41 PM »
No, you can swap lifters about as fast as an oil change..well one side.
Remove valve cover..the 5 bolts holding the rocker shaft down, remove rocker shaft and arms. Then get a magnet flexible rod and pull each lifter out by the big holes between the push rods.
I did mine during a cam swap and I had a lifter tray under the intake that needed to be pushed up while pulling each lifter.
Be sure to break in the lifters like you would a new cam...then again you might as well stick a new camshaft in once you get all the lifters out...
Guess wait until winter  :icon16:
Offline Danishmopar
« Reply #14 on: May 23, 2009 - 04:38:05 PM »
HI...
The lifters are in the shop, ready the change...
Thanks  :cheers:
