Good job...forgot to say about the two long bolts I used to use...get two cheap long bolts..3 inches or so and cut the heads off them (or buy studs) screw them in to each side of the motor were the trans bolts up...just a few threads so they come out easy.
Now you have two long dow pins to start the trans in to...helps when installing a motor also.
