Author Topic: Update To Bleeding My Convertible Top Lines With A New Question  (Read 470 times)
Offline daveh
Ok guys I have the lines completly bleed in my 71 Challenger convertible.  So here's my next question.  The top goes down with out hesitation it's very smooth and on it's own.  But going up on the other hand is a real challenge(no pun intended  ;D).  Unless I stand in the car and pull up until it begins to catch on it's own it won't go up.  Once it's about half way it will finish closing.  But at this point gravity is also taking over.  What do you guys think is the problem?  Thanks
Offline hotrod98
    • Maniac Musclecars
Re: Update To Bleeding My Convertible Top Lines With A New Question
« Reply #1 on: May 20, 2009 - 05:47:49 PM »
The number of problems are limited. Weak pump, bad cylinder(s), bad ground, dry hinge points in the frame, binding due to alignment, bad switch (resistance), bad wiring between switch and pump, kink in the fluid lines somewhere.
When I restored my 70 Challenger convert a few years ago, the top frame assembly had sat outside for a while. Big mistake.
The cylinders were so stiff that the top wouldn't go up and down smoothly and I destroyed a brand new pump.
New pump, new cylinders, new lines and then everything worked great.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
« Reply #2 on: May 21, 2009 - 12:28:26 AM »
, I would lube & align everything first then possibly the pump is too weak
