Author Topic: How much HP can I expect?  (Read 646 times)
Offline sprecks
« on: May 20, 2009 - 07:51:51 PM »
Here's the package. Anyone want to give me an educated guess on the HP?
Hemi with stock cast iron heads.
Stock bore, 4.15 stroke (472 CID)
6.86" Eagle rods
Eagle crank
Diamond pistons 10:1 compression
Custom Grind Cam 0.547" intake, 0.540" exhaust lift
254 deg intake duration @0.050" lift
246 deg exhaust duration @0.050" lift (110 degree centerline)
2-1/8" Hooker super comp headers
2 different induction options:
Stock 2 x 4 intake and carbs or dual plane mopar intake with 850 Holley
What do you think? Is 500 HP a reasonable estimate?
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline 6packCuda
Re: How much HP can I expect?
« Reply #1 on: May 20, 2009 - 08:11:54 PM »
500 sounds pretty conservative. I'd say closer to 600.
Offline sprecks
« Reply #2 on: May 20, 2009 - 09:27:02 PM »
600 would be fun. I sure hope I didn't get carried away and over do it for a street car.
you can call me Jay
Offline heminut
« Reply #3 on: May 20, 2009 - 10:51:02 PM »
Sounds like a pretty solid street package to me. I would guess 600 Hp also!
1970 5.7 Hemi Cuda
moparniac
« Reply #4 on: May 20, 2009 - 11:06:24 PM »
525 tops  :working:
« Reply #5 on: May 21, 2009 - 12:36:49 AM »
600 gross rated 70 HP is about right , 500 net , maybe
Offline Oldschool
  • Member Since 9-05-06
« Reply #6 on: May 21, 2009 - 10:42:44 AM »
Probably 575-600 or so at the crank.  Closer to 500 to the wheels.  Sounds like a good setup....    :2thumbs:
Ken  --  In Georgia
