Author Topic: Lower radiator hose  (Read 1818 times)
Offline shadango
Lower radiator hose
« on: May 20, 2009 - 08:35:42 PM »
Can someone tell me for sure what end is the water pump side of the lower radiator hose?  Figured I would throw this on tonight but for the life of me cant figure which end is which....both seem too long and before I cut it I want to be sure....Got it at autone....maybe they gave me the wrong hose? I have done tons of hoses over the years and most at least seem to work only one way and are pretty obvious...cant figure this one out.... :1zhelp:
Its a Kelly-Springfield M023.....for a 72 Barracuda , 318, no air......Now, I do have a 26" rad in it but folks here said the hoses would be the same..... :clueless:
« Last Edit: May 20, 2009 - 08:40:46 PM by shadango »
Re: Lower radiator hose
« Reply #1 on: May 21, 2009 - 12:34:42 AM »
the end towards your feet should be the rad end
Offline shadango
« Reply #2 on: May 21, 2009 - 05:28:03 AM »
Ok, thanks,,,,so it looks like I have the right hose then? That was my guess but I guess I am going to have to cut both ends to fit?
just seems like the thing is too long.
Offline 426HEMI
« Reply #3 on: May 21, 2009 - 07:26:35 AM »
They do make them too long at times and I have cut hoses to fit before myself over the years.  They try to make them fit more than one thing.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline shadango
« Reply #4 on: May 21, 2009 - 07:42:56 AM »
I guess too much hose is better than too little....... :roflsmiley:
Thanks guys.....I will feel better cutting this.....I guess it is the right one then?
I was wondering if there is a special hose for the 26" rad cars......the guy asked if I had A/C or not and I said NOT cause I dont ...but I do have the 26" rad installed...but not all A/C cars had 26" did they?
« Reply #5 on: May 21, 2009 - 07:48:24 AM »
Lower hose is the same on all small block radiators but the upper hose is different....then you will need to ask for the a/c  or heavy duty hose.
Offline shadango
« Reply #6 on: May 21, 2009 - 08:25:47 AM »
OH CRAP!  I thought the upper hose location was the same on the 22 and 26" rads?  I figured the "A/C" question was more for routing around compressor and stuff?
« Reply #7 on: May 21, 2009 - 08:49:57 AM »
Well don't PANIC... try what you've got....I'm just going by what the parts lists says.  :P
Offline shadango
« Reply #8 on: May 21, 2009 - 09:02:49 AM »
I just called autozone (where I ordered it) and asked if they can also order the other one for me as well...they will both be in this afternoon...... :2thumbs:  .thanks for the heads up!
« Last Edit: May 21, 2009 - 09:07:28 AM by shadango »
Offline shadango
« Reply #9 on: May 23, 2009 - 06:26:42 AM »
Yep......Definately needed the A/C hose!
Looking at the non-AC hose I cant figure out how it even fits a non-AC car..... :dunno:
Thanks for setting me straight!
Will be installing it and the rest of the hoses if all goes as planned today.......  :working:
