Hi all;
Just got the Cuda back from alignment after I replaced the drum brake set-up back to discs. It has new front end rebuild kit, tie rods ends adjuster sleeves, upper, lower ball joints, and LCA bushings. The steering wheel has a little play and the car wander left to right to left going down the road and is very unsetteling to drive at 60+.
Only 17 days to the Hot Rod Power Tour/ Mopower tour!!!
What should I look at first to find the problem?
Thanks!
Don
