Author Topic: Alkyd zinc primer ?  (Read 599 times)
Offline torredcuda
  • Epping NH joined 11/23/03
Alkyd zinc primer ?
« on: May 21, 2009 - 09:05:43 AM »
I can get some Sherwn Williams Alkyd zinc primer free from work and need to know if I can top coat an epoxy type primer over it.It it a marine /industrial type TT-P-645B.Anyone use this stuff or something similar?I have the MSDS but it says nothing for topcaoting.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline dutch
Re: Alkyd zinc primer ?
« Reply #1 on: May 21, 2009 - 01:04:40 PM »
I would try to find out how that stuff behaves when sanding.  If hard to sand I`d stick to epoxy only. ( which doesn`t sand very well either... )
Take some sheetmetal and do some tests  :2cents:
*** Bart ***
Offline torredcuda
« Reply #2 on: May 21, 2009 - 06:43:52 PM »
The zinc primer is sorta like an etch primer in that it is just for adhesion and and corrosion protection,I would immediately shoot an epoxy primer over it.
Jeff
Offline gomangoRT/SE
« Reply #3 on: May 24, 2009 - 11:34:51 AM »
industrial and marine zinc coatings are called "sacrificial" coatings.  Used for bare metal immersion type systems.  It adheres well and is used only for that purpose.  Your intermediate coat (in this case epoxy or whatever you use) should be used within the time frame listed for the product.
