Author Topic: pulley blow up?  (Read 1652 times)
Offline BB73Challenger
pulley blow up?
« on: May 21, 2009 - 08:45:53 PM »
Well, I have has plenty of things break before, but a first was to have a pulley grenade on me today!
I took my car out to bring it home last night and as I pulled into the drive, I heard an odd squeak. Popped the hood and everything seemed OK. No noticeable damage or loose items.
Drove to work... fine.
On my way home, I start to hear a light knock. Boy I'm almost home, better not drag my feet. I leave from a stop light and hear a clunk. Uh oh, check my gauges... hmm..., didn't pitch a belt, it's still charging, only a block away better get her home.
Open the hood...
what the..
Jeff from Cleveland, Ohio
Re: pulley blow up?
« Reply #1 on: May 21, 2009 - 08:47:35 PM »
By the way, the "clunk" was the chunk in the second picture that flew off and hit the underside of the hood.
Looks like I'll be in the market for a quality steel stamped pulley  ;D
Re: pulley blow up?
« Reply #2 on: May 21, 2009 - 08:53:50 PM »
Not cool.... at least no fan trough the radiator  :clueless: where did you get the Made in Taiwan  POS?
Re: pulley blow up?
« Reply #3 on: May 21, 2009 - 09:07:24 PM »
You know I bought both the water pump and crank pulleys a few years ago, and I THINK I remember who it was, but to be honest unless I could say yes I got it from "..." I don't want to just blurt a name out and possibly slander an innocent vendor.
I wonder now to, as you said the rad is OK, and that's because I run a dual electric fan set-up. Would not having a fan bolted to the front of the pulley cause some sort of weakness due to just the 4 screws holding it in place and not a fan?
Offline 6packCuda
Re: pulley blow up?
« Reply #4 on: May 21, 2009 - 09:51:27 PM »
Holy Cow! Good think it didn't dent your hood. I wouldn't think not having a fan on there would weaken it any. :dunno:
Offline dodge freak 2
Re: pulley blow up?
« Reply #5 on: May 22, 2009 - 05:56:25 PM »
Tell the truth now..how many times have you hit 7000 rpms  :D
There was no reason for that expect it was made super cheap.
Offline bb71challenger
Re: pulley blow up?
« Reply #6 on: May 22, 2009 - 06:02:41 PM »
Never even heard of that happening. Man that sucks, like stated above, what would have happened to your hood if it had let go at about 7k? I bet your pulley would be sticking through the hood, definitely not good. I didnt even know that pulleys were repopped.
*Brett*
Offline ntstlgl1970
  • T a c o c a t
Re: pulley blow up?
« Reply #7 on: May 22, 2009 - 06:49:31 PM »
"Would not having a fan bolted to the front of the pulley cause some sort of weakness due to just the 4 screws holding it in place and not a fan"?
IMO It might have something to do with it. Just about any car with a stamped steel w/p pulley has some sort of "washer" on the front of it to clamp the pulley to keep it from flexing (if the pump doesn't drive a fan). The import pulley might also be a lighter gage steel which contributed to the failure.
« Last Edit: May 22, 2009 - 06:52:37 PM by ntstlgl1970 »
Offline dutch
Re: pulley blow up?
« Reply #8 on: May 22, 2009 - 06:56:38 PM »
 :iagree:    there will be a lot more stress to the bolt areas with no fan on it...  those are clearly fatique cracks.
I`d go with billet pulleys. Never seen this happen before though.
*** Bart ***
Re: pulley blow up?
« Reply #9 on: May 22, 2009 - 07:21:15 PM »
Doh, didnt notice the missing fan and extension. Yeah that stuff missing would be a huge factor in the failure imo.
*Brett*
Offline Changin Gears
Re: pulley blow up?
« Reply #10 on: May 22, 2009 - 08:14:07 PM »
Had this happen on my race car a few years ago.  Didn't know it had happen until I got back to the pits and it was handed to me.  A slick had a mark on it where I had run it over.  Was shifting 7800 at the time.  It only drove an alternator.
Offline LAA66
Re: pulley blow up?
« Reply #11 on: May 22, 2009 - 11:17:48 PM »
 Ouch!! All in the same run?
 My dad told me a story about a harmonic balancer coming apart while his friend was tuning (revving) the engine. He ended up with plates in his head from the pieces hitting him.  :22yikes:
