Author Topic: Shaker cable hole  (Read 548 times)
Offline 4 speed fish
Shaker cable hole
« on: May 21, 2009 - 10:52:15 PM »
What is the size of the hole for the shaker cable grommet on the firewall?
Offline ksierens
    • 70 Challenger Resurrection
Re: Shaker cable hole
« Reply #1 on: May 22, 2009 - 08:22:48 AM »
I can check mine tonight, but I would recommend you scribe the circle, then drill it a little undersize and use a rotary file or hand file to take it upto the scribe mark.  If you try to just drill it with the right sized hole saw, it will probably end up oversized.
Kurt - SE Michigan
« Reply #2 on: May 22, 2009 - 11:13:04 PM »
Thanks for the tip.
Offline ksierens
« Reply #3 on: May 23, 2009 - 10:39:08 AM »
Looks like 7/8" ( 0.875 )
Kurt - SE Michigan
« Reply #4 on: May 23, 2009 - 08:13:29 PM »
Thanks for the info.
