Well. I'm not sure about the alignment. I have a stock factory 70 e body bb bell and a 70 340 trans. So I used the spacer ring that came with a lakewood bell housing. Everything sounds good in neutral and shifting at low rpms or even mid rpms. Just when I'm cruisin and higher mph does it get to me. I figured that if I went through the trans first since I don't know the history about it, I could work from there. Maybe buy a new bell from brewers and the right retainer for the trans. ie...bb size.
I'm sure that you have a lot of experience in the 4 spd areas. Anything you say I am tuning into. The car will have a 499 in it soon so I think I need to focus on this problem now. I am thinking I have a bearing problem or something .
What would be needed for a rebuild parts wise? I might should try to have everything here. But I thought a 600 mile trip to brewers and just drop it off might be a good thing to. Since I travel alot. I could have a worn shifter fork as little as I know. I assumed 100k plus miles on the trans. So it wont hurt to have it rebuilt. Performance wise like 1/8th mile runs, it seems to be ok, but for cruise days, I don't like the noise.
I am open for suggestions
