Author Topic: magnum or la stroker  (Read 1772 times)
Re: magnum or la stroker
« Reply #15 on: May 29, 2009 - 02:23:32 AM »
the heads are good for some power increase for sure but I am no fan of the Chev rockers , so I tend to use the 308 heads , they have the flow & the shafts
Offline matt63
« Reply #16 on: May 29, 2009 - 10:36:07 AM »
The Eddy's flow better than stock heads and, if I recall correctly, the Magnum version flowed slightly better than the LA version.  I had a little work done to my Eddy Magnums along with flow testing but I can't recall the numbers.  I wonder how much work is required to get stock iron heads to flow that well?  The Eddy Magnum heads have the smaller 58cc combustion chamber vs the 62/65cc LA and 340 head
Matt in Edmonton
'68 Valiant
« Reply #17 on: May 29, 2009 - 12:24:15 PM »
any alum head needs to have at least 8 cc smaller combustion chamber just to compensate for the heat loss to alum
Offline femtnmax
« Reply #18 on: May 30, 2009 - 11:00:10 PM »
Yes the Edy magnum heads have smaller combustion  chambers, but when you unshroud the valves the chamber CC's goes up about 5-6 cc's, so then you have to mill the heads to drop the cc's back down, and be sure to set the piston tops at zero deck (top of block).
Phil
Offline matt63
« Reply #19 on: June 01, 2009 - 12:37:24 AM »
Yes, zero decking should be the goal along with 10.5 compression w/aluminum heads.
Matt in Edmonton
'68 Valiant
