Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Radiator
« previous
next »
Print
Pages: [
1
Author
Topic: Radiator (Read 1104 times)
kmyles
Sr. Member
Radiator
on:
May 27, 2009 - 06:54:24 PM »
Will a 26" Rad out of a 75 Charger with the matching shroud fit in a Challenger? I currenly have a 22" rad and would like to upgrade to a 26 seeing how it used to be a 318 car, now it is 383.
Logged
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Alaskan_TA
Guest
Re: Radiator
Reply #1 on:
May 27, 2009 - 10:00:17 PM »
22 inchers were used in some 440-6 cars. If you do not have low gears, the 22" may be fine.
Cooler is always better though...........
Logged
shadango
Resident
Re: Radiator
Reply #2 on:
May 27, 2009 - 10:30:29 PM »
I have a 72 barracuda (318 car) running a 318 and I installed a 26".
Just had to drill a couple holes , add some shims I made from pipe/conduit, and add bolts.
Easy as pie.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Radiator
Reply #3 on:
May 28, 2009 - 02:33:30 AM »
basically not easily , the 73 up B bodys have the floating K frame & the rads are a different fit
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Radiator
