Author Topic: Loose water pump belts?  (Read 1421 times)
Offline miketyler
    • www.miketyler.net
« on: May 27, 2009 - 07:10:59 PM »
Hello all - long time no post, I know. Have been busy with new house, a job with increasing responsibility and some minor health issues (more like getting old issues). Aside from that, I still have the Cuda and I took it out over the weekend. Car still runs hot (around 210*) and the warm season really hasnt set in yet here in the DFW,Tx area. Without getting into all the other things that has been advised and tried, I noticed yesterday that I could very easily spin the fan blade by hand.
I am running a custom dual belt setup with a fixed OEM fan. Its not so loose enough that it freewheels, but it requires very little effort to overcome the friction of the belts. The waterpump is part of a 4-pulley belt circuit and there is probably only 1-2" linear that the belts contact the pulley. Anyhow, my question is this; can belts as loose as I describe slip when the engine is running and result in slower WP rpm and consequent hotter temps? I have heard batteries not being charged fully because the alt belt was loose. Could the same be true for waterpump?
Am at the end of the adjustment travel so to test will have to buy a longer adj bracket or fabricate and attach some sort of extension. From what I can deflect by hand, I need to add another 1" of travel to get the belts where the fan cant be turned by hand.
For those that have emailed or PM'd me over the past 6mos or so, please accept my apologies for being so slow to respond. I still have your PMs and will get back to you.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline miketyler
    • www.miketyler.net
Re: Loose water pump belts?
« Reply #1 on: May 27, 2009 - 07:22:37 PM »
a better illustration. I plan to replace or extend the bracket regardless; I was just interested to know what the chances are that this is contributive to my over heat issue.
72' Cuda restomod
70 Mustang Mach 1
Offline miketyler
    • www.miketyler.net
« Reply #2 on: May 27, 2009 - 09:01:49 PM »
Well it took me about 30 minutes to cobble up an extension bar from some .250 thick aluminum I had laying around. Drove it around and car didnt get over 190*. Am hesitant to say its fixed but it sure looks good so far. Will drive around in some warmer outside air temps and see if anything changes.
72' Cuda restomod
70 Mustang Mach 1
Offline 422STROKER
  • Member Since 6/3/06
« Reply #3 on: May 27, 2009 - 09:40:04 PM »
Maybe you can pull the belts and get a shorter set?
Hope that this is your fix. :cheers:
Tom
Tom
« Reply #4 on: May 28, 2009 - 02:51:25 AM »
well I definatly think this is part of your problem , the fan & Wp create drag & it is easily overcome allow it to slip
 the other Big problem I see is that the belt doesn`t actually wrap around the WP pulley, you only have approx 20* of contact , I think you need to have 90* minimum , ideally running the Wp off the power steering belt would be better
Offline miketyler
    • www.miketyler.net
« Reply #5 on: May 28, 2009 - 06:17:51 AM »
yup, thats what I thought too but there is twin belts so that would hopefully make up for it. I am stoked with yesterdays results though. Do thy hve longer adj brackets or will I have to weld an extension to this and have it rechromed?
72' Cuda restomod
70 Mustang Mach 1
« Reply #6 on: May 29, 2009 - 02:41:15 PM »
MIKE....Where's the little Dude in your avatar?.....Always like seeing the little Dude.
Add this to your signature & put the little guy back
Wade
moparniac
« Reply #7 on: May 30, 2009 - 07:30:49 AM »
absolutely true... when i went to the track a couple of weeks ago I threw my alt pulley right off the car..... i pounded it back on and the belt was slipping.. i could see my alt charging guage fluxuating... im sure it will do the same to the wP and cause cooling issues...
Offline ntstlgl1970
  • T a c o c a t
« Reply #8 on: May 31, 2009 - 02:47:23 AM »
"Big problem I see is that the belt doesn`t actually wrap around the WP pulley, you only have approx 20* of contact , I think you need to have 90* minimum , ideally running the Wp off the power steering belt would be better"
I agree - That setup can't be right for the water pump, it needs more belt engagement like CP said.
No matter how tight you make the belt, it is going to slip. And probably ruin your alternator (because you will have it overtightened)
Offline miketyler
    • www.miketyler.net
« Reply #9 on: May 31, 2009 - 09:40:37 AM »
Yes, its bad engineering on my part. I couldnt move it further outboard without having to raise it to clear the valve cover. Since I am running twin belts essentially I have the linear belt contact w/pump x2. I do have it tighter than it was but I dont think its any tighter than it should be.
I cant go any smaller withthe belt size, with the ALT slid all the way in I can barely get my current size belts on.
72' Cuda restomod
70 Mustang Mach 1
Offline 422STROKER
« Reply #10 on: May 31, 2009 - 09:55:13 AM »
So do you plan on making a new A/C bracket to tip it towards the passenger side as far as it can go?
What does the factory set up look like?
Tom
Tom
moparniac
« Reply #11 on: May 31, 2009 - 09:57:59 AM »
electric waterpump  :2cents:
Offline miketyler
    • www.miketyler.net
« Reply #12 on: May 31, 2009 - 04:05:42 PM »
An electric water pump would be cool but they are pricey aren't they? Am pretty sure the readjusted belt setup will be ok but time will tell. I am going to buy one of the 14" universal alternator brackets first and see if I can make it work. If I have to, will cut a piece and weld it on and get it rechromed later.
72' Cuda restomod
70 Mustang Mach 1
