Author Topic: Oil pressure sender/cutoff switch  (Read 1274 times)
Re: Oil pressure sender/cutoff switch
« Reply #15 on: June 02, 2009 - 02:06:11 AM »
the big one is the only one I know of that works for the older guages
Offline the_engineers
« Reply #16 on: June 02, 2009 - 11:30:48 AM »
I'm running a similar set-up, albeit with a slightly smaller sending unit for an aftermarket oil pressure gauge.  I looked for the double 45* fitting that you have, but in the end, just used a T-fitting.  Straight-up to the oil pressure sending unit with the fuel pressure cut-off sticking out of the side.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
« Reply #17 on: June 02, 2009 - 07:11:42 PM »
Can you post a quick pic? Also, where did you get the T fitting? Did you also use a short threaded pipe to get a little extra clearance?
« Reply #18 on: June 02, 2009 - 11:19:33 PM »
After further review, I was right and wrong.  Because of the distributor, I had to come off the block at a 45, and then go into the Tee.
Sorry for the iffy pic.
Brooks
1971 'Cuda 360
« Reply #19 on: June 02, 2009 - 11:21:29 PM »
To answer the rest of your questions...
Hardware store brass NPT pieces.  (2) close nipples, (1) 45 elbow, (1) tee < $10.
Brooks
1971 'Cuda 360
Offline BruteForce
« Reply #20 on: June 03, 2009 - 01:14:32 AM »
Awesome. Your picture and notes make it clear. Thanks!
