Author Topic: Steering column parts  (Read 561 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: May 29, 2009 - 01:19:26 AM »
Hey all,
I've collected most of the parts for my column rebuild but there are a few parts that I'm not finding.  I'm looking for the foam dust shield that goes in between the inner and outer tubes above the lower plastic bearing.  I'm also looking for the rubber o-ring that goes between the two firewall mounting plates.  The last but least important part is the small grommet at the bottom of the column for the trans linkage.
Any thoughts?
Re: Steering column parts
« Reply #1 on: May 29, 2009 - 02:09:50 AM »
I used adhesive foam tape inside the column
Offline plumbeeper
  • Sponsor
    • WOODGRAINWHEELS.COM
« Reply #2 on: May 29, 2009 - 10:04:07 AM »
Talk to Jules. He may be able to supply the parts to you.
www.julesdaddio.com
Offline peterro
    • The Pistonhead
« Reply #3 on: May 29, 2009 - 10:33:28 AM »
Thanks for the contact.
