Author Topic: 70 challenger brake pedal fade manual brakes  (Read 1668 times)
Offline 19challenger70
  • My 70 Challenger
« on: May 31, 2009 - 06:34:22 PM »
Brakes pedal fades I do not see any fluid leaks what could be the problem?
Offline 67vertman
  • Member since 9-23-2005
Re: 70 challenger brake pedal fade manual brakes
« Reply #1 on: May 31, 2009 - 06:41:23 PM »
Does it fade after you used them for awhile?  Or, does the peddle feel spongy?  ;)
« Reply #2 on: May 31, 2009 - 06:44:25 PM »
I have a 70 with manual brakes. The first thought is air in the lines. Are these new brakes? Have you tried bleeding the brake lines?
  • My 70 Challenger
« Reply #3 on: May 31, 2009 - 06:45:44 PM »
The pedal is hard then fades as im on the brakes , Like sitting at a light if i let off the pedal seems to come back then fades again.These are not new brake, problem started first time out for the spring. I do not see any fluid at any wheel or at the junction box on the axle.
« Last Edit: May 31, 2009 - 06:49:02 PM by 19challenger70 »
« Reply #4 on: May 31, 2009 - 08:43:39 PM »
Bad master cylinder. It is leaking through and by passing
Offline 67vertman
« Reply #5 on: May 31, 2009 - 09:15:13 PM »
If the peddle goes soft while your stoped, then it is probably the master cylinder.
Offline heminut
« Reply #6 on: June 01, 2009 - 03:22:27 AM »
I agree with Alan, fluid is seeping past the seals in the master cylinder when pressure is applied.
1970 5.7 Hemi Cuda
  • My 70 Challenger
« Reply #7 on: June 02, 2009 - 08:39:25 PM »
Thanks I talked to a few people and they agree.
Anybody know off a good place to get one?
« Reply #8 on: June 02, 2009 - 08:49:29 PM »
O'Riely's, cae quest, advanced, auto zone, napa, your favorite store. Bargain shop, or rebuild yours :2thumbs:
