Author Topic: Edelbrock LD4B Manifold  (Read 10346 times)
Offline 67vertman
  • Member since 9-23-2005
« on: June 01, 2009 - 08:34:37 PM »
I picked up an old Edelbrock manifold for my 318, it's a 4 barrel dual plane.
Has any body run one before? If so how did you like it?
Offline 71chally416
    • The Streetwalker
Re: Edelbrock LD4B Manifold
« Reply #1 on: June 01, 2009 - 08:40:03 PM »
It might be the best Intake you can get for 318 heads You did good.  :2thumbs:
Offline Oldschool
  • Member Since 9-05-06
« Reply #2 on: June 01, 2009 - 08:48:07 PM »
 :iagree:   That's a good un.....     :grinyes:
Ken  --  In Georgia
Offline 67vertman
« Reply #3 on: June 01, 2009 - 09:01:17 PM »
I am planning on running a Edelbrock 600 CFM on it.  Hopefuly this will cure my stalling problem.  :2thumbs:  Glad to know that I scored a good manifold.  :jumping:
Offline 71chally416
    • The Streetwalker
« Reply #4 on: June 01, 2009 - 10:05:33 PM »
It was good enough for Chrysler to put a part number on and list in the old Direct-Connection catalog. If you haven't bought a carb yet consider the ED 650 Thunder AVS. You can adjust the secondary opening point with a screwdriver :2thumbs:
Offline 67vertman
« Reply #5 on: June 01, 2009 - 10:29:05 PM »
I haven't bought the carb yet, so thanks for the advice.  :2thumbs:
Offline femtnmax
« Reply #6 on: June 02, 2009 - 12:05:23 AM »
I have a Edel 650 AVS with manual choke.  Using the tuning book that came with the carb, I could not dial it in correctly for my altitude of 5000 feet, was running way to rich.
So I bought an Edelbrock 6593 Air/Fuel Ratio Monitor kit.  Was easy to install, and was accurate enough to tune every circuit in the carb:  idle, transfer slots, main jets, secondary jets, and accel pump.   I'm very pleased with the results.  Bought extra O2 sensor fittings for the exhaust manifold so I can use the sensor on other vehicles in the future....like my thermoquad for the 360 I'm building.   :2cents:
Phil
« Reply #7 on: June 02, 2009 - 02:04:20 AM »
the Holley 570 Avenger is great on a 318 & is a better match CFM wise
Offline 72bluNblu
« Reply #8 on: June 02, 2009 - 04:52:58 AM »
Aren't the Edelbrock's rated for dry flow cfm's? I know the Street Avengers are rated for wet flow (fuel and air), which means the 570 cfm Street Avenger puts out 638 cfm at a dry flow rating, comparing apples to apples.
Offline miketyler
    • www.miketyler.net
« Reply #9 on: June 02, 2009 - 08:58:43 AM »
nice manifold - those are getting hard to find.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline UKcuda
  • Tell them I'm on my way
« Reply #10 on: June 02, 2009 - 02:56:37 PM »
I've got one of these as well.
When you say best for 318, does that mean it has 318 size ports ?
'cause mine is sat on an LA 360
'72 'cuda
Offline 71chally416
    • The Streetwalker
« Reply #11 on: June 02, 2009 - 10:34:17 PM »
YES. But it's not a problem if the manifold ports are smaller than the head  :2thumbs:
Offline bb71challenger
« Reply #12 on: June 02, 2009 - 10:41:19 PM »
I had one of those on a 318. I took the Edelbrock and LD4B off with a file and painted the intake to match the engine. It looked pretty stealthy with the factory part number on it. You scored a great 318 intake for sure.  :2thumbs:
*Brett*
« Reply #13 on: June 03, 2009 - 02:51:51 AM »
Well the Avenger probably is wet flowed but it is a tiny carb and very responsive on a 318
Offline 71chally416
    • The Streetwalker
« Reply #14 on: June 03, 2009 - 06:06:46 AM »
In normal times it might be a toss-up what to use on a stock motor, a Holley or a ED carb. Ditto with ED manifolds or one of the others. With today's economy I'll always choose to put my money into the American economy and not send it to China. My :2cents:  :wavingflag:
