Author Topic: need to build speaker grilles  (Read 729 times)
Offline leanburn
« on: June 02, 2009 - 07:46:47 PM »
i have given up on trying to find a set of outside speaker grilles on a 3 speaker dash, the set i bought have way to much curve and i have found a few more that are the same, way to much curve. so i'm going to build something but not sure how and what. i'm not worried about looking stock but i definately want them to look clean and that they belong there. a friend had a brain fart and suggested to use a thin steel plate [ 16 guage maybe ] , cut to fit and simply drill a bunch of holes in it. this sounds way to easy so i'm looking for more ideas. :roflsmiley:
 it would be nice to still get some small speakers in there still, anyone have suggestions?
Re: need to build speaker grilles
« Reply #1 on: June 02, 2009 - 09:36:24 PM »
Offline leanburn
« Reply #2 on: June 02, 2009 - 09:45:42 PM »
have you used these before. i assume they would easily bend to the shape of my dash. those are probably the ticket, thanks.
« Reply #3 on: June 02, 2009 - 09:58:37 PM »
Never used them but at 3" I doubt much bending would be needed... I'd remove some foam from under the vinyl & let them recess down as far as I could.
 Another thought is the late 70-s - 80s GM cars like Monte Carlos had a thin plastic trapezoid grill that might be easy to find.
Offline duodec
« Reply #4 on: June 13, 2009 - 09:37:48 PM »
You could check a craft store to see if they have a molding kit for molding plastic.  User your too-curved ones as a reference to make a mold, and make a new set in plastic (plast-aid or something similar).  Even with the curve in the mold the plastic parts should have enough flex in them to allow use.
I'm certain you'd have to hand-work the back side of the plastic copies to fit; I don't know if the craft-type kits can do both sides, but if you search you might find something that can for not too much money.
Offline Justins72
« Reply #5 on: June 15, 2009 - 01:32:29 PM »
If you do decide to go the mold making route there is a video that shows how to make a two part mold that way you can mold the back and the front for a close to perfect mold.  They also sell all the supplies you would need to make the mold.
heres the site with the video.
http://www.tapplastics.com/info/video.php#video26
Offline the_engineers
« Reply #6 on: June 15, 2009 - 04:47:10 PM »
I bought a 2' x 2' sheet of perforated steel at my local home improvement store to use as a spark arrester on a burn barrel.  It might give you the look you're after.  They had several styles in brass, aluminum and steel.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
