Author Topic: tranny (727)  (Read 2738 times)
Offline paneldriver@fairpoint.net
tranny (727)
« on: June 04, 2009 - 04:11:30 PM »
how do you tell what year a tranny is(727)
Offline tactransman
Re: tranny (727)
« Reply #1 on: June 04, 2009 - 05:22:41 PM »
to CC.com! There is stamped numbers on the case by the pan rail in front of the neutral safety switch. I have a chart to see what the number is to the year. Also the Valve Body will have a date code right on it ,but that could have been swapped.
Terry-tactransman
Union, Mo.
Re: tranny (727)
« Reply #2 on: June 04, 2009 - 05:41:11 PM »
thanks for that let me ask this if i could . I bought a b&mtranspak #10228 for a 727 out of a 1970 fury III all original so they say and i have no reason to dought one owner car. I am useing the street mode , put the valve body does not have it all, the down shift assembly is just the cover on the valve body, and there is no spring in the middle of the booster valve assembly. Is this ok  also if i am looking down at the valve body the 1-2 and2-3are the only valves the picture shows 1 above those two is that a different year or what.thanks ED
Offline tactransman
Re: tranny (727)
« Reply #3 on: June 04, 2009 - 06:22:32 PM »
The Kit should be fine. If you look on your VB,the last two numbers of the year are on it. (yours should say 70)
Terry-tactransman
Union, Mo.
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
Re: tranny (727)
« Reply #4 on: June 04, 2009 - 06:31:06 PM »
tactransman, your inbox is full  :smokin:
Offline tactransman
Re: tranny (727)
« Reply #5 on: June 04, 2009 - 07:03:17 PM »
Thanks,fixed it!  :smokin: :smokin:
Terry-tactransman
Union, Mo.
Offline shadango
Re: tranny (727)
« Reply #6 on: June 07, 2009 - 10:09:29 AM »
Hey Terry...
Is there anywhere online that the chart can be seen?   I am curious as to what mine is....
Offline tactransman
Re: tranny (727)
« Reply #7 on: June 07, 2009 - 01:43:19 PM »
I had the info in this thread,but the pics got cleaned out (again) by the "upload folder clean out process"  :stomp:   :lol: I will do a new thread with the info and have the data stored some where else so the pics/info will stay there. I will not be able do it till tuesday when I get back to the shop.
http://www.cuda-challenger.com/cc/index.php?topic=36046.0
Terry-tactransman
Union, Mo.
Offline Ck[FIN]
Re: tranny (727)
« Reply #8 on: June 07, 2009 - 03:44:36 PM »
Do you mean this kind of chart?
Offline tactransman
Re: tranny (727)
« Reply #9 on: June 07, 2009 - 04:03:30 PM »
No,it is a 5 page chart.
Terry-tactransman
Union, Mo.
Offline tactransman
Re: tranny (727)
« Reply #10 on: June 09, 2009 - 11:39:13 AM »
Terry-tactransman
Union, Mo.
Re: tranny (727)
« Reply #11 on: June 13, 2009 - 08:54:07 PM »
thank you for the information,  the # ON THE VALVE BODY INSIDE THE STAR IS # 4 THE NUMBER ON THE SIDE OF THE CASE IS PK4329438  8578  9934  THIS DOES not fit the chart you showed any guess's on the year, how do i know if the valve body is a manuel or auto shift is there a way to tell you could share please  :feedback: please  please
Offline tactransman
Re: tranny (727)
« Reply #12 on: June 13, 2009 - 09:18:32 PM »
It is on the last chart on the far right column, '84-'85 Dodge Truck with a 318. :cheers:
If you post some clear pics of the VB I can probably tell you manual or automatic shift.(it is probably an automatic shift)
Terry-tactransman
Union, Mo.
Re: tranny (727)
« Reply #13 on: June 14, 2009 - 10:12:56 AM »
You are the best thank you so very much.    I see in the older 727 's [70-74] the rear spline is smaller then in the newer ones what year did they change. and thanks again. Ed
Offline tactransman
Re: tranny (727)
« Reply #14 on: June 14, 2009 - 01:46:31 PM »
If you mean the output shaft spline,they are all the same thru all the years.
Terry-tactransman
Union, Mo.
