Tach
Author Topic: Tach  (Read 637 times)
Offline VTMopar
Tach
« on: June 04, 2009 - 09:50:12 PM »
I put my Rallye Guages in a few weeks ago, and everything was working great.   Tach worked fine, probably not as sensitive as one that has been re-built -- but it worked fine.    Out for a ride today and all of a sudden the tach goes crazy -- drops to zero then back up to 2,000 then down -- jumping up and down.   No change in the motor.... ran just fine.   I stopped for gas and re-started -- all was fine.   I guess I'll have to take it all out this Fall before I lay her up for the winter and have her rebuilt -- but does anyone have any ideas what could be causing this?    I have a MOPAR electronic ignition; tach wire mounted to the (-) side of coil.
VT Mopar
VT MOPAR
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: Tach
« Reply #1 on: June 04, 2009 - 10:33:50 PM »
loose wire?
bad ground?
 :dunno:
hey did you ever get your chrome for the belt molding ordered?
Go Fast & Have Fun...
Offline VTMopar
Re: Tach
« Reply #2 on: June 04, 2009 - 10:56:01 PM »
I checked the wire at the coil.    Probably need to pull the whole guage set to figure out if the ground is loose....  Haveing just installed it -- think I'll wait until Fall (it's not THAT much fun).....
No, still haven't found the Qtr Belt Moldings.   :1zhelp:
VTMopar
VT MOPAR
    • THE DODGE BOYS
Re: Tach
« Reply #3 on: June 05, 2009 - 05:29:10 AM »
I will keep looking for that order info from my set.  :cheers:
