Author Topic: firm feel steering box adjustment  (Read 5084 times)
Offline leanburn
« on: June 05, 2009 - 05:24:38 PM »
i just installed  one of these and when i start the car the wheels spin to the drivers side. how do you adjust this?
moparniac
Re: firm feel steering box adjustment
« Reply #1 on: June 05, 2009 - 05:45:28 PM »
huh?
did you make sure it was in the center before installing...... left to righ wheel lock centering i mean :working:
Offline leanburn
« Reply #2 on: June 05, 2009 - 06:43:55 PM »
i found out my problem, i need to centre the spool valve.
« Reply #3 on: June 05, 2009 - 10:15:30 PM »
Yes just loosen the bolts & tap the housing up or down a small amount
Offline whitewatersky
« Reply #4 on: August 05, 2015 - 11:42:33 PM »
mine was pulling all the way to the right as soon as you start the car.
after adjusting with a good tap, it now will stay centred, but at the SLIGHTEST steering input either way, it will pull completely to the direction I start turning
nice and light tho !
does anyone suggest anything further ?
(T/A with power steering)
« Last Edit: August 21, 2015 - 05:21:51 PM by whitewatersky »
Plum Crazy auto T/A Challenger
Offline 1 Wild R/T
« Reply #5 on: August 05, 2015 - 11:56:07 PM »
Sounds like the spool valve is binding... I think you need to pull the valve body off the box, pull it apart, & polish the valve....
Offline crash340
« Reply #6 on: August 06, 2015 - 12:01:08 AM »
whitewater, that is not functioning correctly, I have a stage 2 FF box and its not light, nor does it want to go in any direction, i have to turn the wheel which I believe is what it should be like.
Greg
73 Cuda
Brisbane, Australia
« Reply #7 on: August 06, 2015 - 01:36:58 AM »
thanks guys,
I'll see if we can get into it tomoro
pretty wild ride in its current state - drive-able tho....
« Reply #8 on: August 06, 2015 - 07:17:03 AM »
:iagree: I have stage 3 and it's the same as above. I'd contact FF  and see what they suggest.  :2cents:
Offline Mopar Mitch
« Reply #9 on: August 06, 2015 - 10:41:52 AM »
Its likely the valve body on top of the ps box that is not centered properly... I've learned in the past...   Lift the car (at least the front end), remove the wheels so there is as little weighted resistance in the steering as possible (or else, better yet, you could disconnect the pitman arm from the crosslink arm, thereby, truly eliminating resistance)... then, with the engine running, you adjust the valve body back/forth until it has become as near perfect as possible without its automated self turning.   The key is to lift the car and remove all resistance, then adjust.   You'll probably lose some fluid, so have a catch pan underneath.
« Reply #10 on: August 11, 2015 - 06:31:59 PM »
Hey Mitch, thanks for that. Just curious why the removal of resistance will work as opposed to doing with the wheels on the ground.
Will try it today.
Thanks
Offline crash340
« Reply #11 on: August 11, 2015 - 06:38:32 PM »
I'd imagine taking the load of the front tires would enable the setting of the valve body to be perfect, a little resistance might have you setting up what seems good but is slightly off.  :dunno:
Greg
73 Cuda
Brisbane, Australia
« Reply #12 on: August 11, 2015 - 11:20:12 PM »
might be more to this.
power steering fluid is leaking now...
i'll update later today...
Offline Mopar Mitch
« Reply #13 on: August 13, 2015 - 02:38:20 PM »
WW - as stated just before.. to remove as much friction/resistance as possible... this is fine-tuning.. and critical.. There may be some other way to do this adjustment on a work bench if it would be rebuilt... I'm certain "Steer and Gear", as well as "Firm Feel" would know.. you might want to contact them (both.. to see if they'd give the same answer).   Do you live closer to one vs the other?  S/G is in Colombus, OH.... FF is in Oregon or Washington out west.
« Reply #14 on: August 15, 2015 - 01:26:36 AM »
thanks man - bloody long way from both - halfway upi the East Coast of Australia -  :bigsmile:
we'll rip into it next week.
back in the '65 Riviera for the weekend
