Position from the rear window molding clips
Author Topic: Position from the rear window molding clips  (Read 626 times)
Offline 4yuckfous
« on: June 05, 2009 - 11:28:42 PM »
Where is the exact position, from the two long clips, for the rear window molding on a 1970 Cuda?
What’s the exactly function for those two clips?
The streets don't get wider, if you drive slower !
Re: Position from the rear window molding clips
« Reply #1 on: June 06, 2009 - 12:19:49 AM »
 :clueless:  they are all the same size. You mean the 2 metal pieces to center the back window for installation?
Offline 4yuckfous
« Reply #2 on: June 06, 2009 - 12:45:47 AM »
 :clueless:i think, to pieces about 2" long
« Reply #3 on: June 06, 2009 - 08:25:21 AM »
those would go on the bottom to line up the window when installed. Most people dont use them , they use 1/4 inch rubber . Glass shops tell me that the metal ones can cause a chip in the glass after installation and cause it to crack.
But to answer your question, towards the lower outer edge for glass support, but not in the corners.
