Author Topic: ***Sheet Metal Welding Woes...Need Advice***  (Read 4318 times)
Re: ***Sheet Metal Welding Woes...Need Advice***
« Reply #30 on: June 08, 2009 - 06:13:38 PM »
.. Good eyesight.....I'm Doomed to mediocrity......
    How about the red afterglow...seems like the better spots glow a little longer where the ones that don't look poor & every now & then one stays red hot a lot longer but still looks OK.
Offline hemiken
« Reply #31 on: June 08, 2009 - 06:35:06 PM »
Hey Wade, can you take a picture of the backside amd show us the penetration you are getting with your welding ? this will answer some questions to whether some welds are to hot or not hot enough buddy. :2thumbs:
Offline Ross
« Reply #32 on: June 09, 2009 - 01:35:50 PM »
 :popcorn:
'70 340 Challenger
A whole lot of rust and very little time to work on it...
« Reply #33 on: June 09, 2009 - 08:52:41 PM »
Thought I'd move over to fresh area to keep it simple... 1st off welded with gas off looked wrong right off duuuuu.. anyway 2 welds looked good to me  1st pic front, second backside...Keep in mind this patch is about 3" tall.
« Last Edit: June 09, 2009 - 09:22:20 PM by Bullitt- »
wagesofsin
« Reply #34 on: June 09, 2009 - 09:07:39 PM »
looks fine, and yes the gap may be to large, but thats not an issue. tack onto one side, wait a sec, tack on the other side and bridge. just be patient. thats better than some ive seen.
it will get better, and as was mentioned, you will become a welding feind!!!
Re:AYEE**Sheet Metal Welding Woes..RASIN FRASIN*
« Reply #35 on: June 12, 2009 - 11:46:31 PM »
Finished welding the newer patch then ground down the excess  :pullinghair:  one side of the patch you could see light through practically the whole length...no "welding" just melted metal piled on top...2 sides did OK & the bottom, with the relatively large gap (thinner than a dime) did great.
  Sooo somewhere in my memory I have seen that a bit of a gap was intentionally left, while most material on the subject never mentions this... Any thoughts?
Offline hemiken
« Reply #36 on: June 13, 2009 - 12:12:46 AM »
You are correct Wade, the smallest of gaps is a good thing when welding with a mig welder, but if you were doing a butt join and welding with Oxy/Acetalyene then you would need the panels to fit flush against one another tightly to get best results.  You are mig weldind and a little gap does help with the penetration and excess wire forced into the join by the mig itself :2thumbs: your doing great :woo:
