Author Topic: caster vs camber  (Read 767 times)
Offline noschevys
caster vs camber
« on: June 07, 2009 - 06:21:13 PM »
If I set the camber to -.5*, will that automaticaally set the caster to max?
Re: caster vs camber
« Reply #1 on: June 08, 2009 - 01:16:28 AM »
No
to max the caster you need to turn the front eccentric all the way out & the rear all the way in , then back off the setting slightly if you need to correct the camber
Offline noschevys
« Reply #2 on: June 08, 2009 - 06:12:23 AM »
Does that mean the lobe on the front eccentric points towards the fender and the rear eccentric points towards the engine?
« Reply #3 on: June 08, 2009 - 09:40:44 AM »
No just the opposite
Offline noschevys
« Reply #4 on: June 08, 2009 - 01:21:35 PM »
Here's what I got with a stock front end and radial tires BFG 235 60R15.  Left side camber -.5*, castor +2*.  Right side camber -.75*, and castor +1.5*.  Is this good for every day driving/cruising?  Also is the difference from left to right side ok with the crown in todays roads?
« Reply #5 on: June 08, 2009 - 07:28:21 PM »
depends on the crown but I think you probably have it as good as it gets
