Author Topic: vin bs23l4b207275 1974 Barracuda  (Read 2925 times)
Offline lowe408
« on: June 07, 2009 - 07:50:52 PM »
I was told this has a original 360 engine, it has the 360/4 barrel breather but has a holley 2 barrel carb.  where would I find the numbers on the engine, thanks
Alaskan_TA
Re: vin bs23l4b207275 1974 Barracuda
« Reply #1 on: June 07, 2009 - 08:08:17 PM »
Look for a raised pad on the passenger side of the engine. It is about the middle (front to back) slightly above the oil pan rail.
The transmission number is on the passenger side also, on the bell for automatics & on the case for 4-speeds. You may as well take a look for it while you are under there.  ;)
Best of luck, & welcome to the site.
Offline lowe408
« Reply #2 on: June 07, 2009 - 08:59:56 PM »
I found on passenger side that looked like 6dn3 24 73    / on drivers side  4006830  360 5 let me know if any of these looked right. Thanks
Alaskan_TA
« Reply #3 on: June 07, 2009 - 09:06:20 PM »
This;
 6dn3 24 73    is the casting date.
This;
4006830  360 5
is the casting number. The 360 means 360 CID, so far so good.
The VIN numbers are stamped in, much smaller than the cast numbers. Take another look where I mentioned.
Offline lowe408
« Reply #4 on: June 09, 2009 - 06:20:48 PM »
It looks like 9a 4880?
Offline lowe408
« Reply #5 on: June 09, 2009 - 06:29:36 PM »
trans. looked like 4b2u7275 not sure on the u
Alaskan_TA
« Reply #6 on: June 09, 2009 - 08:26:20 PM »
Well, based on your post title;
"vin bs23l4b207275 " the u is likely a 0 & your trans is a match.
I have no clue what the 9a4880 could be, are you looking in the right spot?
Try & get clear close up photos of both VIN pads if you can just to be sure.
