Author Topic: volt meter  (Read 798 times)
Offline pink panther
volt meter
« on: June 08, 2009 - 04:15:45 PM »
I have aftermarket volt/oil/ water temp guage, the volt quit working, is there a way to check the guage itself?  Battery is fully charged, where else should I look?
Re: volt meter
« Reply #1 on: June 08, 2009 - 06:13:38 PM »
Scott,
  Do you have a voltmeter? If so, you can measure across the battery terminals with the engine running. You should see about 13.8 Volts. If not, then it's not your gauge that is at fault. This is the easiest test I can think of before you start taking the dash apart.
Re: volt meter
« Reply #2 on: June 08, 2009 - 06:43:13 PM »
Mike, I do, the battery is good, I'm asking if I can test the guage? it is aftermarket triple guage set up, where do I start to find where the guage / reading is bad?
Offline 422STROKER
  • Member Since 6/3/06
Re: volt meter
« Reply #3 on: June 08, 2009 - 06:46:44 PM »
Check the voltage at the back of the gauge with a DMM or equivalent.
Tom
Tom
Re: volt meter
« Reply #4 on: June 08, 2009 - 07:26:44 PM »
Assuming the guage has power to it / is connected still & has ground then the guage has failed
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
Re: volt meter
« Reply #5 on: June 10, 2009 - 09:08:14 PM »
Disconnect one of the wires from the voltmeter. Attach a 9V battery across the gauge with some test leads. It should show 9 volts on the gauge.
