Author Topic: 11.75" disc caliper mounts  (Read 593 times)
Offline FJ5_440
  • Wisconsin
« on: June 08, 2009 - 11:21:14 PM »
I'm looking for a pair of 11.75" disc caliper mounts.  Sliders would be preferred, as my slider calipers are new.
email me at
 bmkesmg at yahoo dot com
** Shane **
Re: 11.75" disc caliper mounts
« Reply #1 on: June 09, 2009 - 02:32:55 AM »
If you do not come up with a set in a reasonable time frame Email me , I believe I have an extra set but I am not sure I will be down to check before Carlisle now
 Or I could swap for pin type as I have new pin calipers
« Reply #2 on: June 09, 2009 - 06:38:26 PM »
Ok I checked & I have 2 spare sets of Caliper adapters , 1 for the 10.7" & one for the 11.8"
 both are the slider type
 I offered the 11.8" set to TC first so I need to see if he needs them
 I also have a set of the 11.8" slider type for my Chall but could swap for pin type
Offline FJ5_440
  • Wisconsin
« Reply #3 on: June 09, 2009 - 09:58:46 PM »
Thanks for checking.  If TC doesn't need the 11.8" pieces please let me know how much you want for them.  I have struck out locally, as most auto recyclers around here don't hang onto anything more than a few years old.  I will keep looking.
** Shane **
« Reply #4 on: June 09, 2009 - 10:48:20 PM »
Thanks CP.
 I plan to re use my existing Calipers which are the pin type. That is the type I would actually want to go back with since I already re built the calipers.
Offline FJ5_440
  • Wisconsin
« Reply #5 on: June 10, 2009 - 07:26:12 AM »
Great price CP, unfortunately I already got a set.
I ended up hitting the buy it now on an ebay auction shortly after my last post.  I knew I should have been more patient because now I have to pay $100 for the ebay set.
** Shane **
