Author Topic: 360 Engine mounts  (Read 476 times)
Offline CUDA JAS
  • vroooooom!
360 Engine mounts
« on: June 09, 2009 - 02:20:22 PM »
Any one have pics of propely installed engine mounts for a 360 (the engine side)?
I have a sneaky suspision that mine are not correct (can you even screw these up?).
Thanks,
Jas
74 'cuda 360/727
Just call me a gearhead!
Re: 360 Engine mounts
« Reply #1 on: June 09, 2009 - 06:15:07 PM »
the 318 & 360 use a different left side mount the 360 is offset forward or rearward 1/4" from the 318 mount
Offline femtnmax
« Reply #2 on: June 10, 2009 - 12:03:11 AM »
My understanding is the drivers side mount width where it attaches to the block is same for 318/340, but unique for 360.  I believe the 360 mount is wider.
RH mounts are supposed to all be the same.
Phil
Offline 73challenger_TN
« Reply #3 on: June 10, 2009 - 12:52:04 AM »
I used washers to fix mine.... :-)
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: June 12, 2009 - 01:43:57 PM »
Hmm, i did the same thing on my drivers side. I guess it will work for now.
On the pass side, how should the bracket mount, looking from the front of the block, is it bracket first then the block, or the reverse?
Jas
74 'cuda 360/727
