So it works on the bench and not on the car. Here's what I'd do. Set it beside the car, and with test leads hook it up to power and ground, spin the rotor by hand and see if it sparks (if it works on the bench, this should work no different.) Then, keep spinning it by hand while you stick it in the distributor hole. When it stops working that should be where the problem is!
