I have a 440-6 in my car. 22 inch factory tank radiator. I had a rad shop install a 3 row core. When I built my engine, I cleaned as much as I could behind the freeze plugs. I also did my heads , then the front of my block with wire brushes inside the water ports. Then I found my best water pump housing that wasnt showing any signs of pit wear. Then I bought a non a/c water pump from Car quest. Once the engine was tuned, timed and adjusted. I havent had a single over heat problem. I installed a 180 thermostat and the car runs 185 to 195 in so far 93 temps. If your timing is off or you are running fat on your jets, the engine can run hot. When I am driving 3500 rpms for a long distance the car will run 195/200.
My stuff is all stock but have zero problems. I also run the stock 68/71 non ac pullies, factory fan shrou, and a factory stock thermal fan. J 10 y plugs and factory jetting in the carb. And have the rubber hood to cowel seal on my hood to.
