I tried the blue springs.,..no change really......so I went up to the pink.....no change....
One other thing I noticed that it is doing....it idles rough and lumpy and at about 800 rpm.....if I gas it a few times the rpms stay high , around 1300-1400....if I tweak the throttle screw back just a hair the rpms drop right back down.....(and the linkage isnt binding or anything)......
At 4, 6 8 & 10 degrees initial timing the idle doesnt change much but the throttle response is HORRIBLE......very boggy.........so I bumped it back up to around 10-12 * and the reponse is somewhat better but still boggy and the idle is the same.......
Manifold vacuum at 800 rpms is measuring 4-5" hg....when I drop it into gear, rpms go to 400-500 and like 1" HG of manifold vacuum...........
I feel like I am going in circles....
Was thinking about checking the float settings but I cant find the gaskets locally and have to order them...not sure if I could pull the airhorn assembly and check the floats and jets etc and then reassemble without new gaskets or not.,
I just feel like I must be missing SOMETHING.....
......could my control module be hooked up wrong somehow? The (new) wiring harness I have had plugs for the 5 pin control unit and the 4 pole resister......I figured if I had any of that stuff wrong it wouldnt run at all...
(Thanks for the help and listening to me whine....I am justreally bummed about how this is (not) progressing.....
