Author Topic: Brad's 1970 Challenger, living the dream! The evolution continues!  (Read 189266 times)
Re: Brad's 1970 Challenger, living the dream! The evolution continues!
« Reply #255 on: April 30, 2014 - 06:43:21 PM »
Scored this off Kijiji last night for less that half what the store wanted. Brand new in the box , just assembled it.. Should come in handy for the fender mods. I've already been warned about thumbs and fingers.  :lol:
Just what I needed.... more stuff in my garage!  :icon16:
Offline Tonker1
« Reply #256 on: April 30, 2014 - 08:33:44 PM »
I for seeing a lot fun in your future!
Offline dutch
« Reply #257 on: May 01, 2014 - 01:47:29 AM »
cool.  :2thumbs:
*** Bart ***
Offline hemiken
« Reply #258 on: May 01, 2014 - 10:01:06 AM »
Hey Brad, their is a method to how you should cut the fenders buddy, it will make your job much easier if you would like me to tell you how my friend. :wave:
« Reply #259 on: May 01, 2014 - 03:01:13 PM »
Sure fire away, I'm always learning!  :2thumbs:
My plan was to cut out the wheel well area where the stock molding goes on. Space it out the required amount then build up to it, then cut out what's behind that I don't need?
« Last Edit: May 01, 2014 - 03:03:11 PM by brads70 »
Offline Jamiez
  • Retro
« Reply #260 on: May 01, 2014 - 04:43:36 PM »
Those are some big tires up front!  And more neat shop tools!  Should be a fun summer!
Offline hemiken
« Reply #261 on: May 01, 2014 - 07:32:51 PM »
Hey Brad,
This is how i would start with cutting the fender.
Every cut should be parallel to the fender main side body line that runs horizontal, mark a cut line using a chalk line and then use a length of masking tape to show the horizontal straight line and this will be the guide line for cutting that is positioned half way from the body line to the top part of the fender beauty line, then using a square i would line up where the lower body line front and rear of where the arch of the fender beauty line turns and follows the bottom portion of the fender, this should be where you stop and start your cutting. The fender will flex outwards enough if you cut it in this way to allow you a square straight section to work from, easiest way i know how.
Using 2 support rods, space out the fender cut area to allow the proper width to what you need for clearance, all of these modifications should be done while the fender is still mounted to the car to get proper shape and pattern making.
Their is a next stage after you get to this point, let me know you understand what i have written as a guide buddy :2thumbs:
Kenny.
« Reply #262 on: May 01, 2014 - 08:23:26 PM »
I understand what your saying . Great pictures!  :2thumbs: But right now the fender lip is sitting on the tire. . My thoughts are when the lip goes out the required amount it also needs to go up. I REALLY want to reuse the stock wheel well molding too.
Also another detail that needs to be factored in is the front bottom portion of the wheel well lip needs to be moved to clear the tire when the wheel is turned. I figure a pie section starting at the bottom about 3/4" tapering up to nothing at the body line. I'm hoping the molding will bend to accommodate this? Might have to slit the trim to bend it?
« Last Edit: May 01, 2014 - 08:30:54 PM by brads70 »
Offline Mopar Mitch
« Reply #263 on: May 02, 2014 - 06:50:38 PM »
That purple Challenger in the autocross looks awesome.. what area does he live in and where abouts does he race?
Offline hemiken
« Reply #264 on: May 02, 2014 - 07:53:27 PM »
Hey Brad,
The reason i have drawn the slicing like i have is so you can still use the wheel arch molding and not have to modify it at all buddy. You will get enough flex out of the fender to clear the tyre when you peel it over leaving it fully attached on  the bottom section, simply put the car up on a jack and peel the cut section to clear the tyre when you let the jack down, this will give you the correct clearance you will need from fender to tyre, just adjust it accordingly from their.
Get you fender to this stage and i can tell you what the next step is if you like. :2thumbs:
Offline tommyg29
« Reply #265 on: May 03, 2014 - 09:47:43 AM »
Wow,
I hadnt looked in here in a while, and you have been busy.
I love the new wheel/tire setup, but I wouldnt have the guts (or the skills or tools) to start cutting on my fenders.  :22yikes:
All I can say is have fun, and good luck  :2thumbs:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #266 on: May 03, 2014 - 09:51:32 AM »
I know it's in the San Jose area, my buddy sent me pics of it when it was in the body shop he uses there
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
« Reply #267 on: May 03, 2014 - 10:05:58 AM »
Cool car, love the quality of the build. Not a fan of the Chevy engine,( or the fender flairs) but other than that ..... things you can do when money is not a factor huh?  :)  It has most of a Challenger body and interior but that's about where it stops being a Mopar?  :-\
http://www.youtube.com/user/TheCris930/videos
JCG 70 Challenger @ USCA Laguna Seca 2014
http://www.lateral-g.net/forums/showthread.php4?t=41291
« Last Edit: May 03, 2014 - 10:08:02 AM by brads70 »
Offline anlauto
« Reply #268 on: May 03, 2014 - 01:03:01 PM »
Stop Dreaming...Start cutting !
Offline HP_Cuda
  • Mopar or No Car!
« Reply #269 on: May 03, 2014 - 02:04:45 PM »
Just go for it, if you over think it you may get results that Alan looks for!
 :roflsmiley:
