Brad's 1970 Challenger, living the dream! The evolution continues!
Author Topic: Brad's 1970 Challenger, living the dream! The evolution continues!  (Read 189161 times)
Re: Brad's 1970 Challenger, living the dream! The evolution continues!
« Reply #345 on: January 14, 2015 - 07:21:39 PM »
Well.... It's winter and I'm bored again.  I'm planning on building my own K-frame still using torsion bars and A-Body LCA's , Schroeder double splined hollow sway bars and arms( I have a couple different diameters to try 1 1/4" and 1 7/16"),and a Mustang rack.  Not in any big hurry. Timeline....this summer or next? Right now I'm in the parts procurement process.  A buddy gave me a pair of spindles/steering arms used in Nascar.
http://www.laughlin-racing.com/productlist.asp?cid=17
I modified them to suit a Howe screw in ball joint and to get the front end geometry I want. I started with this.
Then ended up with this.
I also bought a couple chunks of aluminum to machine up my own hubs that will allow these Wilwood  rotors to bolt too as well as having the 4 1/2" bolt pattern and light weight. Rotors are ordered just waiting on them to come in so I can start the hubs .
http://www.wilwood.com/Rotors/RotorProd.aspx?itemno=160-6844
I've been taking to Bill Reilly of RMS on facebook and he is coming out with his own spec'ed mustang rack that sounds really good, so I'll wait till he has it available.
For brake calipers I got a pair of 2005 Mercedes AMG 8 piston calipers. Today I found some time to work on them. I got them tore down for rebuilding and paint. The pistons are ceramic. Cool stuff, should work good!
« Reply #346 on: January 14, 2015 - 07:30:13 PM »
I also bought a set of gauges from Speedhut.  http://www.speedhut.com/  They are really great to work with! You can design your own any way you want, colours, fonts, etc... I could never get the speedo to read correct ( I have a 4L60 transmission) and Speedhut uses GPS, that and I get rid of the problematic amp gauge. I designed mine to mimic the stock 1970 Gauges.
I'll wait till it warms up a bit to install them in the car.
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #347 on: January 14, 2015 - 08:30:18 PM »
Pretty Cool Brad, What's your plan on the K-frame ,design layout , tubular or Square Construction. I assume your gonna keep the torsion bars... Front steer or rear steer ..? I'm waiting too on Bill's steering Rack.  It is supposed to have the same valving as the 94 Cobra rack ,    :bigsmile:
« Last Edit: January 14, 2015 - 08:34:02 PM by johns cuda shop »
« Reply #348 on: January 14, 2015 - 08:40:39 PM »
Hi John,
Square, Tubular construction with front steer. Yep keeping the torsion bars.  :2thumbs:  Bill seems like a great guy! Sounds like a straight shooter. His steering rack sounds great! :2thumbs:
Offline RCCDrew
« Reply #349 on: January 14, 2015 - 09:04:15 PM »
Cool innovation! Love it!
« Reply #350 on: January 14, 2015 - 09:22:55 PM »
Nice, I notice some new spindles , is the
I notice some new spindles, my guess that's gonna change some of the geometry a bit.
« Reply #351 on: January 14, 2015 - 09:24:58 PM »
Yes it will, it will lower the roll centers.  ;)
http://vsusp.com/?tool=2d#0.8%26project_name%3ABrads70%20cup%20spindles%26trim%7Bbody_roll_angle%3A0%7Cfront.left_bump%3A0%7Crear.left_bump%3A0%7Cfront.right_bump%3A0%7Crear.right_bump%3A0%7D%26front%7Bframe.susp_type%3A0%7Cframe.bottom_y%3A16510%7Cframe.center_to_upper_mount_x%3A44577%7Cframe.bottom_to_upper_mount_y%3A27939%7Cframe.center_to_lower_mount_x%3A33654%7Cframe.bottom_to_lower_mount_y%3A4445%7Ccontrol_arms.upper_length%3A19431%7Ccontrol_arms.lower_length%3A33020%7Cknuckles.hub_to_upper_x%3A17208%7Cknuckles.hub_to_lower_x%3A13335%7Cknuckles.hub_to_lower_y%3A6984%7Cknuckles.hub_to_upper_y%3A20637%7Cknuckles.hub_to_strut_axis%3A14000%7Cknuckles.strut_incl%3A8000%7Cwheels.offset%3A-1270%7Cwheels.diameter%3A1800%7Cwheels.diameter_expl%3A35000%7Ctires.size_convention%3A0%7Ctires.section_width%3A31500%7Ctires.aspect_ratio%3A3000%7Ctires.diameter_expl%3A50000%7Ctires.width_expl%3A7620%7D%26rear%7Bframe.susp_type%3A0%7Cframe.bottom_y%3A9200%7Cframe.center_to_upper_mount_x%3A28500%7Cframe.bottom_to_upper_mount_y%3A24000%7Cframe.center_to_lower_mount_x%3A17000%7Cframe.bottom_to_lower_mount_y%3A2400%7Ccontrol_arms.upper_length%3A24800%7Ccontrol_arms.lower_length%3A37500%7Cknuckles.hub_to_upper_x%3A15000%7Cknuckles.hub_to_lower_x%3A13000%7Cknuckles.hub_to_lower_y%3A13000%7Cknuckles.hub_to_upper_y%3A13000%7Cknuckles.hub_to_strut_axis%3A14000%7Cknuckles.strut_incl%3A8000%7Cwheels.offset%3A4000%7Cwheels.diameter%3A1500%7Cwheels.diameter_expl%3A35000%7Ctires.size_convention%3A0%7Ctires.section_width%3A19500%7Ctires.aspect_ratio%3A4500%7Ctires.diameter_expl%3A50000%7Ctires.width_expl%3A7620%7D%26pref%7Bdiag1.px_per_mm%3A200%7Cdiag1.front_or_rear%3Afront%7Ctab.active%3A0%7Cunits%3A0%7Cshow.f%3A1%7Cshow.ca%3A1%7Cshow.k%3A1%7Cshow.w%3A1%7Cshow.t%3A1%7Cshow.rc%3A1%7Cshow.ic%3A1%7Cshow.fvsa%3A1%7Cshow.tl%3A1%7Cshow.kpil%3A1%7Credraw_during_drag%3A1%7Cchart.x_axis_center%3A0%7Cchart.x_axis_window%3A10%7Cchart.x_axis_num_steps%3A21%7Cchart.x_axis_field%3Atrim.body_roll_angle%7Cchart.y_axis_fields%3A%5BFR%5D.general.roll_center.y%7D
Offline dutch
« Reply #352 on: January 15, 2015 - 01:32:18 AM »
cool stuff Brad.  I bet hitting those brakes will feel like throwing out an anchor.
Did you already get a chance to check accuracy on the temp gauge?
*** Bart ***
« Reply #353 on: January 15, 2015 - 08:13:48 AM »
No too cold here now to start the engine. I'll wait till it warms up to install them in the car.
« Reply #354 on: January 15, 2015 - 08:29:28 AM »
cool Stuff Brad .. look forward to your updates
Offline 360FISH
  • BS23H3B567746
« Reply #355 on: January 15, 2015 - 04:10:58 PM »
Those gauges look cool...  I like the idea of going GPS too.   Do the needles light up as well as the rest of the dial?
Looking forward to seeing them get installed.
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
« Reply #356 on: January 15, 2015 - 04:14:27 PM »
I believe they do light up as well. The backs light up green ( like stock) at night but you can choose from a few other colours too.
If you go on the web site you can "play" with different combo's and colours, different style needles etc...
Offline 360FISH
  • BS23H3B567746
« Reply #357 on: January 15, 2015 - 04:16:53 PM »
Yes, I've been there and it's like being a kid in a candy store!   So many choices I can't decide what I like best...
Kind'a like deciding what color to paint my car...  I'll never decide...
Thanks
Alan
« Reply #358 on: January 19, 2015 - 02:56:12 PM »
Still too cold to work in the garage much , so I'll do the little things. Painted up the 8 piston AMG calipers today. I had to bake them in the oven at 200 degree's for an hour. Hope the wife doesn't catch on to the "smell"  :icon16:
Offline MOPAR FANATIC
« Reply #359 on: January 19, 2015 - 04:38:55 PM »
 :drool: Swwweeeet............. and as for the wife,ya she'll smell 'em............. better go buy her another pair of shoes now brad.  :smilielol:
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
