Author Topic: Bolt Chart  (Read 1719 times)
Offline txchallenger
Bolt Chart
« on: June 12, 2009 - 01:03:19 PM »
Does anyone know if there is a bolt and screw chart available for being to identify what type and size screw goes where? I know vendors offer bolt/screw packages and individual screws but having to try to figure out exactaly what I need as far as #sizes and type is a pain. AMK has all the screws but I don't know the sizes and style I need and I don't need the entire master kit.
Hope this makes sense.........
Offline shawge
  • Zoiks!!
Re: Bolt Chart
« Reply #1 on: June 12, 2009 - 01:37:39 PM »
Yes, there is a manual showing each bolt/screw/nut and where it was located.  I'll look through my saved links and post back.
- Jerry
Offline aarcuda33
Re: Bolt Chart
« Reply #2 on: June 13, 2009 - 07:30:24 AM »
 Heres the link I believe you are looking for
  http://www.mmcdetroit.com/Market_Place/
 The book are kind of expensive . Hope this helps
Offline snowdog
  • Thor-Our Belgian Tervuren-Member since 2006
Re: Bolt Chart
« Reply #3 on: June 13, 2009 - 08:48:51 AM »
Wow, for guys like us that have basket cases or almost basket cases that would be well worth it.  Especially if you took it apart 20 years ago,...........like me.   :roflsmiley:
See ya,
Snowdoggie
Scott (aka: snowdoggie) 1970 Challenger - 440 Modified - 4 Spd - White on Black - 1970 Cuda - 383 Magnum - 4 Spd - Drk. Green on Black - Howell, MI
See my "I'm gonna fix'm up someday" story at Cars in Barns.  **Dodge Main 76-78**
http://www.carsinbarns.com/Mopars%20In%20Barns/pg113mopar.htm
Re: Bolt Chart
« Reply #4 on: June 13, 2009 - 10:12:59 AM »
Thats is what I am looking for thanks aarcuda33
Offline HemiOrange70
Re: Bolt Chart
« Reply #5 on: June 13, 2009 - 11:04:06 AM »
I am having the same issues. I used moparts.com under tech for engine bolt sizes and mymoparts also has some bolt sizes. I bought an interior screw kit and front screw kit (grille-headlights) and they are well worth the cash. Fender bolts are available at a bodyshop supply place so don't pay big bucks for those. good luck
Offline NoMope Greg
Re: Bolt Chart
« Reply #6 on: June 13, 2009 - 02:42:44 PM »
See ya,
Snowdoggie
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline Purple73Cuda
Re: Bolt Chart
« Reply #7 on: June 13, 2009 - 03:21:35 PM »
I bought a few manuals a few years ago. They were expensive (around $85 ) but well worth the money. The info in these books is very valuable to me. They show different head markings and call out  lengths and types of finishes used on the fastener. They show every screw and bolt for the car.
I highly recommend buying these manuals.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline snowdog
Re: Bolt Chart
« Reply #9 on: June 13, 2009 - 09:48:30 PM »
Thanks, Topcat & aarcuda33,
Its people like you and well everybody else that helps us fellow Mopar Guys out that makes this site great!  I'm going to save those links.
Se ya,
Snow Doggie
Re: Bolt Chart
« Reply #10 on: June 13, 2009 - 10:01:09 PM »
You're welcome Snowdog.
I've been doing it to alot of my hardware and I can attest that the money spent and little time put in will pay for itself.
Some of my other remedies on removing the rust also is to use straight Evapo Rust, tumbler media, into tumbler, for an hour or so works very fast. Gotta really tighten the wing nut down really tight. About an inch on the bottom of rust solution in the tumbler is all you need.
After you do the sealing 2nd dip (yellow colored) in the Eastwood kit, put outside in a sunny location away from pets and kids.
Offline aarcuda33
Re: Bolt Chart
« Reply #11 on: June 13, 2009 - 10:56:50 PM »
 Snowdog
 I work at my job so many hours I dont have time / energy to work on my cars, dont even have one I can drive . Getting on cc.com every night and reading about you guys cars and projects gives me my mopar fix !!!
 It is all of you who deserve the thanks
 aarcuda33
Re: Bolt Chart
« Reply #12 on: June 14, 2009 - 11:09:43 AM »
Great links TC.......Thanks for the info     :clapping:
