Author Topic: Header bolts - use lock washers?  (Read 3812 times)
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
« on: June 12, 2009 - 11:59:25 PM »
After endless trial fits, I'm ready to torque up the header bolts. Should I use lock washers? Any gotchas I don't want to learn the hard way? :clueless:
Offline bb71challenger
Re: Header bolts - use lock washers?
« Reply #1 on: June 13, 2009 - 12:05:15 AM »
From my meager experience I would say no. Just use quality header bolts. The hardened lock washers get "annealed" by the heat of the headers and actually start coming apart in my experience.
*Brett*
Offline BruteForce
« Reply #2 on: June 13, 2009 - 12:29:18 AM »
Glad I asked! I thought the answer would be "you moron, of course use lock washers!" I've also got some hi temp anti-sieze compound for the threads.
The bolts are the high strength ones from Tacoma Screw. They're expensive, but since I only need 12 the cost is trivial compared with trying to get out one that broke off!
« Reply #3 on: June 13, 2009 - 12:59:10 AM »
I am not an authority on headers so wait for confirmation before scrapping the lock washers. I have been wrong before   :wave:
*Brett*
« Reply #4 on: June 13, 2009 - 01:12:48 AM »
Offline Changin Gears
« Reply #5 on: June 13, 2009 - 08:40:08 AM »
What I have found with header bolts or nuts is that they don't actually loosen, the gasket compresses.  You have to go back and re-tighten them 2 or 3 times after temperature cycles.  Once you do this you're all set.
The dead-soft copper gaskets minimize this.
Offline 73EStroker
« Reply #6 on: June 13, 2009 - 03:32:04 PM »
My TTIs came with flanged header bolts only. No washers. And yes they will lose their tension with the heat and cause all sorts of problems. As mentioned recheck them for tightness about a day after using them and a couple of weeks of running. Should be ok after that
Barry (Salmon Arm)
