Misc performance and restoration parts for sale
Author Topic: Misc performance and restoration parts for sale  (Read 986 times)
« on: June 13, 2009 - 01:10:29 PM »
An odd assortment of restoration and performance parts from MP, ARE, and others. Buyer pays shipping in most cases from 80907. I've got pictures of everything so if there is something you want to see, just ask. PM here or email me at highplains@comcast.net
Thanks for looking!
Tony
$150    5" Autometer carbon fiber 10k tach
$125    Black Magic electric fan
$90    440 pushrods 9.265"
$20    pinto a arms
$40    15" Magnum trim rings
$30    70 Road Runner front turn signals
$30    B&M unimatic 5" cable
$10    dual point sets
$10    battery box
$515.00   Wilwood brake kit; Dynalite calipers, pads, brackets, spindles
$205.00   Hurst Pistol Grip Shifter (1970-74 E-Body, 1971-74B-Body with Console)
$75.00   adj pinion snubber 8 3/4
$65.00   alum shackle bushing
$50.00   Super Bee Emblem — Grille (1969 Super Bee)
$50.00   low deck big block tall throttle bracket
$50.00   360 tall throttle bracket
$50.00   W2 tall throttle bracket
$50.00   Abody  Lwr arm poly pivot
$50.00   RB block tall throttle bracket
$50.00   axle shim set
$45.00   kickdown cable style bracket
$45.00   BB throttle cable
$40.00   T-bar removal tool
$30.00   C body washer bottle
$30.00   B/E ball joint socket
$30.00   Hood Pin and Cable Kit
$30.00   “440 6-bbl” Hood Decal
$30.00   Upper ball joint separator
$25.00   t-bar adjuster block/screw
$25.00   J bolt for gas tank straps
$25.00   8.75 pinion thrust washer kit
$24.00   BB chrome dist hold down
$20.00   Lower control arm bracing plate, A, B, E
$20.00   Lower control arm bracing plate, late B
$20.00   66-70 steering wheel assy
$20.00   67 GTX back up lenses
$20.00   big block throttle return set for tall linkage set
$15.00   Standing RR w/ helmet decal
$15.00   Porting Template big block— 2.08/1.74 Valve Size, Cast Iron Head
$10.00   340 main bearing set
$10.00   upper control arm cam bolt assy
$10.00   heater hose bracket 67-68 big block w a/c
$10.00   3/8 tank filter sock
$10.00   '74 Dart grill
$9.00   Red engine enamel
$5.00   74 Plymouth hub caps
$5.00   spare tire hold down wing nut
$5.00   universal ign wire loom
$5.00   thermostatic switch
$5.00   NOS big block throttle return spring
$5.00   OE ignition key blank
$3.00   valve lash decal
$3.00   DC large decal
$1.50   SB exhaust manifold sleeve nuts
$1.00   5/16 corbin clamp
$1.00   3/8 corbin clamp
« Last Edit: August 30, 2009 - 12:14:00 PM by HP2 »
Re: Misc performance and restoration parts for sale
« Reply #1 on: August 30, 2009 - 12:14:20 PM »
Updated list above.
Offline quapman
    • Auto-Grip on Facebook
« Reply #2 on: August 30, 2009 - 05:16:45 PM »
What kind of deal would you make on the ball joint socket and T-bar tool?
Thanks
« Reply #3 on: August 30, 2009 - 05:53:11 PM »
How about if I pay postage, that's worth about $8.
