Author Topic: Shifter Linkage Levers  (Read 1001 times)
Offline tb3cuda
« on: June 13, 2009 - 06:50:59 PM »
I've got a pile of shifter linkage levers but am not sure what is correct for my e body.  Can anyone tell from the pics or does anyone have the part #'s.  The pics on Brewers site didn't help me.  Thanks
Offline vinb
Re: Shifter Linkage Levers
« Reply #1 on: June 13, 2009 - 09:29:47 PM »
Man I'm I confused.. :clueless:
I think the 3th , 4th & 5th levers...
There should be a two digit number stamped on them...
I'll have to look at mine.....
« Last Edit: June 13, 2009 - 09:31:42 PM by vinb »
« Reply #2 on: June 13, 2009 - 10:50:23 PM »
L to R: 4th, 5th and 6th ones.
« Reply #3 on: June 14, 2009 - 01:25:14 AM »
well a lot of the E body ones had the double holes to shorten the shift throw & none of these are that type so
 I would use the from the Right,
 1 for reverse
 3 for 3-4
 5 for 1-2 with the offset away from the tranny & the rod on the inside of the lever
Offline tb3cuda
« Reply #4 on: June 14, 2009 - 01:33:23 AM »
Cool thanks guys
Offline vinb
« Reply #5 on: June 14, 2009 - 01:06:38 PM »
Ok here's the deal.....
Offline tb3cuda
« Reply #6 on: June 14, 2009 - 04:34:17 PM »
VinB you went above and beyond!  Thanks again
« Reply #7 on: June 15, 2009 - 02:47:28 AM »
those are the double hole levers I was talking about
thanks for the pix Vin
Offline vinb
« Reply #8 on: June 16, 2009 - 10:01:08 PM »
Anytime guys... :thumbsup:
