Author Topic: which headers provide the best ground clearance  (Read 4032 times)
Offline 71chmark
Re: which headers provide the best ground clearance
« Reply #16 on: July 28, 2009 - 05:10:56 PM »
I have Thorleys on my 440 which I believe are the same as Dougs (since Thorely is his last name). I got them from Summit.  Uses the stock starter. Can you see em'?
I may be schizophrenic,
Offline pink panther
« Reply #17 on: July 28, 2009 - 05:16:46 PM »
I have Hooker super comps on my 340, passenger side sits a little lower than driver, no clearance issues unless you are driving over big speed bumps
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #18 on: July 30, 2009 - 12:48:15 AM »
I checked the clearance on my car today and it looks like if I convert to the Doug's I will pick up a good 4 inches of ground clearance. So i think I will go that route. Thanks everyone for the input. Now I just got to get the money together to do, because not only am I going to replace the headers but while I'm in there I will put the power steering back in and a mini starter.
1996 Dodge Viper GTS Coupe
Offline 422STROKER
  • Member Since 6/3/06
« Reply #19 on: July 30, 2009 - 07:59:47 PM »
Sounds like the way to go to me!
Tom :2thumbs:
Tom
Offline mikerallye
« Reply #20 on: August 02, 2009 - 09:31:21 PM »
Are you looking for measurements?
I can get the Doug's measurements for you if you want.
I like to drive mine everywhere and it sits pretty low in the front no issues.  The roads aren't so hot here either with plenty of speedbumps. :eek4:
Tom
Hey Tom, what is that knob thing hangin to the left of the driver side header?   :clueless:
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #21 on: August 02, 2009 - 09:44:32 PM »
i use the tti headers,,i live off  a gravel driveway road  and never drag
72rtchallenger
what happens in the garage
stays in the garage
Offline 422STROKER
« Reply #22 on: August 02, 2009 - 10:33:09 PM »
Brake Proportioning valve.  I swapped to Discs from drums and added it for adjustability.
Tom :2thumbs:
Tom
