Author Topic: Just installed the HHR fan  (Read 16404 times)
Re: Just installed the HHR fan
« Reply #15 on: June 24, 2009 - 11:57:51 PM »
I think I'm going to try this fan too. Wiring is so not my thing. Can anyone post some wiring diagrams? And part # for the relays and thermo switches? Painless has relays?
I need a sort of a "wiring for dummies" kind of thing?  :smilielol:
Anyone?
Offline BIGSHCLUNK
« Reply #16 on: June 24, 2009 - 11:59:57 PM »
I think I got my relay "kit" from Jegs!  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline miketyler
    • www.miketyler.net
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #18 on: June 25, 2009 - 07:16:59 AM »
I was looking at a painless kits they seem to be for 30 amps most of them. Is that enough? Does anyone know how many Amps the HHR fan draws?
Offline quagmire
  • Traction Impaired......
« Reply #19 on: June 25, 2009 - 12:37:56 PM »
All of the standard Bosch relays are 30 amp rated, and work with this fan.  You can install two for redundancy in case one fails if you want.  Any part store will sell those for about $5-$7 dollars, don't waste money on a kit that contains nothing else but a higher price.  Whether you want a thermal or manual switch to control it  is up to you.
Offline Justins72
« Reply #20 on: October 30, 2009 - 09:59:01 PM »
So how has this fan been working out so far?
Offline quagmire
« Reply #21 on: October 31, 2009 - 05:39:36 PM »
Perfect, no issues whatsoever.  It cools very well, and is pretty quiet too.
Offline Strawdawg
    • Vortex Buicks
« Reply #22 on: November 02, 2009 - 09:10:39 AM »
What are the dimensions of the fan and how deep is it?  Looks like a really useful set up.
Offline quagmire
« Reply #23 on: November 02, 2009 - 05:07:00 PM »
Don't have the exact numbers written down, but if you look up the part on Rock Auto and click on info a picture with dimensions will pop up.
Offline Strawdawg
    • Vortex Buicks
« Reply #24 on: November 02, 2009 - 10:59:37 PM »
I shoulda known that!  :)
« Reply #25 on: February 02, 2010 - 04:52:13 PM »
I am running this fan in my dart.........
Did you get it wired up yet?
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
« Reply #26 on: June 05, 2010 - 12:02:49 PM »
Just got almost everything to put the HHR fan in to my challenger. Great fan and the price for everything was less then 120.00 for an amazing set up.
« Reply #27 on: June 05, 2010 - 01:43:22 PM »
 :iagree: :2thumbs:    I'm up to my elbows with wiring at the moment, my HHR fan is almost wired up! Adding a MSD , and relays for the headlights etc....
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
« Reply #28 on: June 14, 2010 - 02:56:32 PM »
You should always use a relay when installing a high current draw accessory like this, even if you use a manual switch.  Mine uses a relay activated by a coolant temp switch installed in the intake manifold.
I need help with ordering this part.  There are choices to make at Rock Auto and I am clueless as to what to order...  For example:
Have to choose between the HHR LS or HHR LT.
Then have to choose between the 2.2L or 2.4L application.
Finally, I see that it states 'for AC cars'.  Does this matter if I don't have AC?
Did you purchase the 'relay activated coolant temp switch' from Rock Auto as well?
Any Part Numbers and part list would help.
Thanks
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
« Reply #29 on: June 14, 2010 - 04:40:07 PM »
I used a painless wiring relay kit. easy as pie to wire up! comes with thermo sensor too!
