Author Topic: List of parts for a complete front end rebuild  (Read 558 times)
Offline Chlngrcrzy
« on: June 15, 2009 - 10:15:41 PM »
Okay. i was able to save my control arms, but will need to find some new control arm pivoting bolt for both sides. Anyone know where to find these?
Here is a list of what i think i will need to rebuild my front suspension, if i have left  anything out or there is a better alternative, please chime in.
Rh lower ball joint, Lh lower ball joint.
Rh upper ball joint, Lh upper ball joint.
LCA Bushing, left and right
LCA pivoting bolt, left and right side.
Upper control arm Bushing and Cam bolt set, left and Right.
Strut Rod Bushing set, left and Right.
End link Kit
Sway bar frame bushing set
Tri castle nut set
.92 Torsion Bars
Torsion Bar Dust boot and clip set
2 outer tie rod ends
2 inner tie rod ends
pitman arm
idler arm
I think that is it.  :clueless: Let me know if i am missing something, before i start shopping for prices.
« Last Edit: June 16, 2009 - 12:16:04 AM by Bullitt- »
Re: List of parts for a complete front end rebuild
« Reply #2 on: June 16, 2009 - 01:43:42 AM »
I use the Moog Parts , you can replace the tie rods & sleeves with the larger C body parts for the same cost
