Author Topic: Rear Sway Bar Links ????  (Read 1094 times)
Offline Pentastar Pete
« on: June 16, 2009 - 08:27:45 AM »
Does any know the size of the rear sway bar links?? The bar was not on the car, so I don't have the old ones.
I have a set that came with the car, not sure if their the right ones... No # on them.  :banghead:
Or   does anyone know a part # for the rear links..   I also have to dig up the 8 bolts that hold it to the frame. Don't think thats a big problem.
It's for a 74 Challenger  Factory Rear Sway Bar....
Thanks
74 Rallye Challenger
73 Rallye Challenger
68 Charger RT
Re: Rear Sway Bar Links ????
« Reply #2 on: June 16, 2009 - 12:24:01 PM »
I usually bolt through the frame with long 5/16" bolts
Offline BGan5150
  • 1973 Challenger
« Reply #3 on: December 10, 2009 - 11:16:52 PM »
No one had the rear that I found. thankfully, I had my worn original - the Autozone guy pulled every Mopar link in stock and found the A body front link to be the same as the E body rear.  It fit perfectly.
« Reply #4 on: December 11, 2009 - 12:18:24 AM »
I have used the Poly Energy links at the same length as well
Offline ksierens
    • 70 Challenger Resurrection
« Reply #5 on: December 11, 2009 - 08:08:46 AM »
I bought mine from a member here (farmboy70) they look like the origional and have poly bushings.
I also bolted my bar through the frame.
Kurt - SE Michigan
Offline ragtopdodge
« Reply #6 on: December 14, 2009 - 10:10:24 AM »
I still have some sets of these if needed. I think these are the same for 69 B-body fronts also some others.
How much?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
