Author Topic: Anyone heard of chaining an engine down?  (Read 1546 times)
Offline tommyg29
« on: June 16, 2009 - 04:05:50 PM »
Chaining a 440-6 to the K-member to help prevent breaking mounts? Seems to make sense, but I've never heard of it before.
Thanks. Heres a picture.
Offline the_engineers
Re: Anyone heard of chaining an engine down?
« Reply #1 on: June 16, 2009 - 04:11:05 PM »
I've seen several iterations, although the most common is a turnbuckle from the K-Frame toand ear on the motor.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: June 16, 2009 - 04:13:12 PM »
My small block is chained down. I kept breaking mounts, even with a small block.
1996 Dodge Viper GTS Coupe
sleepychallenger
« Reply #3 on: June 16, 2009 - 05:23:14 PM »
mine is chained down too.
Offline tommyg29
« Reply #4 on: June 16, 2009 - 05:34:12 PM »
I guess it depends on the type of mount on that left side, but how much slack do you think should be allowed before there aint no mo :bigsmile:
sleepychallenger
« Reply #5 on: June 16, 2009 - 05:35:43 PM »
i took out as much slack as i could
moparniac
« Reply #6 on: June 16, 2009 - 05:49:42 PM »
I have solid motor mounts and a schumacher torque strap......  :working:
Offline dutch
« Reply #7 on: June 16, 2009 - 06:01:12 PM »
what does that feel like inside the car?  much noise?
*** Bart ***
moparniac
« Reply #8 on: June 16, 2009 - 06:08:18 PM »
NO NOISE at all... it makes the whole car shake like a pro stocker  :cooldancing: the engine is locked down......  :working:
Offline vinb
« Reply #9 on: June 16, 2009 - 06:33:29 PM »
Simple,  1"x 1/4"x 36" Aluminum a little twist on the bottom, done deal.......
Offline leanburn
« Reply #10 on: June 16, 2009 - 08:04:42 PM »
that flatbar setup looks good. would there be any concern on that much torque on the head?
Offline vinb
« Reply #11 on: June 16, 2009 - 08:38:31 PM »
Not really....
First it's only a street car and second maybe 350 hp. (that ain't no power).
I would be more concerned with the pair of steel engine mounts with the torque pulling on the cylinder....
If you have a high horsepower car with big tires I would make a motor plate....
Offline leanburn
« Reply #12 on: June 16, 2009 - 08:44:58 PM »
not really, it's a warmed up 340 with aluminum heads.
Offline vinb
« Reply #13 on: June 16, 2009 - 09:52:51 PM »
leanburn,
Do you have a stick or automatic?
I think you would be ok with it. If you do one like mine I would put a Heli-coil in the head where it bolts to.
There are many ways of doing it and make it look good.
If you want to go with a steel mount, put it on the passenger side only and the strap on the driver side..
Offline leanburn
« Reply #14 on: June 16, 2009 - 10:00:31 PM »
i'm an auto with transbrake.
i broke a motor mount last weekend so i need to do something, that flatbar looks like it belongs there, not like a chain or turnbuckle.  :2thumbs:
