I woudl remove the sifter , get the carpet positioned as far forwrd as possible , it should go behind the heater box a little , trim around the Gas pedal & column & work you way back & trim very carefully around the shifter , I assume it is auto so the left side needs to be left extra long to hide behind the console , it is easy to trim off too much
