Author Topic: Hot Car Won't Turn Over  (Read 1907 times)
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
« on: June 18, 2009 - 12:31:56 PM »
My 360ci 4bbl auto does not turn over after it's been run.  I get nothing:'( After waiting awhile, it struggles to turn over and then fires.  The car starts up when it is cold after a few pumps and holding it to the floor before I turn the key (I personally don't like this either).  It has the regular fuel pump and ignition system. I did install a new mini-starter, plugs and wires in September.
This summer is my first chance to drive her to hot temperatures since we purchased it in August.  So I haven't gone through much... Any suggestions?
« Last Edit: June 18, 2009 - 12:38:03 PM by joltinjoe »
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Re: Hot Car Won't Turn Over
« Reply #1 on: June 18, 2009 - 12:56:51 PM »
I doubt the relay is the problem but check to be sure it is activating , I suspect the new mini starter is the issue
Offline 72bluNblu
« Reply #2 on: June 18, 2009 - 02:41:41 PM »
Sounds like the solenoid is shot. Sometimes these are just bad from the factory, I replaced my stock starter (for the same exact reason) with a rebuilt one from Kragen and had it die within a week. They replaced it, but its not uncommon with the new electrical stuff. On a slightly different note, I went through about half a dozen condensers on my Austin Healey before getting one that worked. Manufacturing standards in China aren't all that great, and if there's a flaw the insulation breaks down under heat and causes the non-starting issue. Once cooled it works again, but as you know only until it gets hot.
I believe you can just get a solenoid for the mini-starters, that way you wouldn't have to replace the whole thing.
« Last Edit: June 18, 2009 - 11:53:02 PM by 72bluNblu »
« Reply #3 on: June 18, 2009 - 02:54:59 PM »
the end plate si easily removed to access the solinoid contacts , cleaning then or aligning them may fix the problem
« Reply #4 on: June 18, 2009 - 02:56:47 PM »
If you have headers, it's possible you are overheating the starter as the tubes are real close by. It may need a heat shield.   :dunno:
Offline JoltinJoe
« Reply #5 on: June 18, 2009 - 03:26:14 PM »
I don't have headers but I was going to add a heat shield anyhow down the road.
Offline MJS73
    • Mike's 1973 Challenger
« Reply #6 on: June 24, 2009 - 11:49:47 PM »
You beat me to it.  Mine cranks slower (but cranks and starts) if I do a quick re-start.
www.mikes73.com
Offline BIGSHCLUNK
« Reply #7 on: June 24, 2009 - 11:55:57 PM »
Had a similar prob on a pont I had.... STARTER!  :grinyes:  (heat shiled I'd try first tho....)
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Oldschool
  • Member Since 9-05-06
« Reply #8 on: June 25, 2009 - 08:12:30 AM »
I have also found that with too much timing they will start great when cold, but lag terribly when hot.  Just another idea....    :2cents:
Ken  --  In Georgia
Offline JoltinJoe
« Reply #9 on: June 25, 2009 - 10:44:35 PM »
The only Heat Shield that I've found is from Thermo Tec.  Any others?
« Reply #10 on: June 26, 2009 - 01:00:20 AM »
just the reflective insulating wrap or build your own
Offline hebeegbz
« Reply #11 on: July 25, 2009 - 12:51:18 AM »
I tend to think if most cars work with out a heat sheild then it wont help .
not to  say never but on custom fit issues a heat sheild may be needed but its a mask not a fix . look at whats in front of you the failed part is looking back .
as another said look at the timing and relay even the battery can be the cause if older or sits for long periods un used .
thread gone in 60 seconds
Offline jeryst
« Reply #12 on: July 25, 2009 - 12:54:34 AM »
I had the exact same thing happen, and it was the starter. Replaced it, and the problem went away.
Offline drewcrane
« Reply #13 on: July 25, 2009 - 01:58:19 PM »
 :wavingflag: here is the starter i ordered cause i have the same problem ,the elect. system is all good and has been checked, the battery is good,the starter is ok except when its hot, so my racing buddie told me about tilton and he has been using the same starter for 13 years here it is,
http://www.summitracing.com/parts/TIL-54-10000/?image=large
Offline JoltinJoe
« Reply #14 on: July 25, 2009 - 02:29:18 PM »
Has your racing buddies application been on stock cars as opposed to race cars?
