new MP valve covers, how about pcv valves.
Author Topic: new MP valve covers, how about pcv valves.  (Read 3325 times)
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« on: June 18, 2009 - 01:47:56 PM »
Hi guys..
I got me a new set of MP valve covers for 70´ 318 cui. But how abot the pcv system ?. are there a system there fit the covers and the MP aircleaner baseplate...
Tired of the engine smell in the car  :eek4:
Thanks Guys.
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
Re: new MP valve covers, how about pcv valves.
« Reply #1 on: June 18, 2009 - 02:16:38 PM »
You have a few options. Mopar makes a valve cover accessory kit that has grommet, caps, and bolts to do this. Get them from any Dodge dealer or Mopar Performance supplier.
Another option is to drill out one of the circular blanks cast in the cover to fit a grommet of your choosing.
Third option is to replace one of the twist on caps with a grommet to hold the pvc. A factory big block valve cover pvc grommet works well in that hole. Stateside we have universal grommets available at part stores to do this trick. Might check with a locally part place and see if there is something close.
« Reply #2 on: June 18, 2009 - 03:03:20 PM »
If you bought a set of the cast aluminum covers, you can punch out one of the circle-like areas for the PCV valve. I know it doesn't look like it, but those holes just punch out.
Offline Danishmopar
« Reply #3 on: June 18, 2009 - 04:37:31 PM »
 :cheers:
Are the posible to get a carburator base plate with hose barb from the pcv valve, or should it run to the carburator...
How will the pcv valve setup works, Pcv valve in the one cover and a breater in the other one ?
Thanks Guys
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #4 on: June 18, 2009 - 05:06:51 PM »
Bro, I improvised a PCV system using sepcters PCV, I had to find a gromet to fit the PCV and had to use a large hose and use two hoses to connect it to the carb, like a step system large hose sealed to a smaller one that fits into the carb.  Here is a pic of my set up.
Don
Member Since January 14, 2002
« Reply #5 on: June 18, 2009 - 06:38:23 PM »
 :cheers:
Thanks Guys
Running the PCV to the carb is the best way to go. It can also be mounted to a carb spacer, or aftermarket intake manifold. Yes, the PCV valve is on one cover, and a breather would mount on the other cover.
I'll post a pic of mine. The passenger's  valve cover has the PCV valve in the back, along with a grommet. The driver's cover has a breather in the front.
Offline vinb
« Reply #6 on: June 18, 2009 - 09:30:37 PM »
I used the factory pcv grommet and the mopar grommet stuck them together.
And a breather on the opposite side. Don't forget to install the baffles....
« Reply #7 on: June 18, 2009 - 10:34:18 PM »
Mopar accessory kit. Three grommets, a spare cap and chrome bolts.
Offline Danishmopar
« Reply #8 on: June 19, 2009 - 02:24:56 PM »
Thanks Guys..
Parts are orded, Thanks.
 :cheers:
« Last Edit: June 21, 2009 - 09:23:06 AM by Danishmopar »
Offline Danishmopar
« Reply #9 on: June 21, 2009 - 09:24:43 AM »
Hey again Guys..
Where can i get the right Pcv valve for the MP valve covers. Checket out summit, No Luck.
 :thumbsup:
moparniac
« Reply #10 on: June 21, 2009 - 09:53:38 AM »
yep  :working:
Offline 422STROKER
  • Member Since 6/3/06
« Reply #11 on: June 21, 2009 - 12:49:50 PM »
Hey again Guys..
 :thumbsup:
Should be a regular parts store PCV for the grommet.
Tom
Tom
moparniac
« Reply #12 on: June 21, 2009 - 01:21:11 PM »
I just tapped a fiiting into my indy intake and ran braided line in there and made my own hole in the indy vc's....   :working:
Offline Danishmopar
« Reply #13 on: June 21, 2009 - 03:28:58 PM »
Thanks Guys for all the respons.
In my local parts store they only have parts for Nissan´s and Toyota´s Damm they Rizeres..
 :2thumbs:
