Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
How do you remove steering coupler?
« previous
next »
Print
Pages: [
1
2
Author
Topic: How do you remove steering coupler? (Read 4970 times)
brads70
C-C.com Expert
on:
June 21, 2009 - 10:59:47 PM »
OK I'm stumped. I'm switching steering columns . Column shift to Floor shift. How do you remove the coupler? I have a new kit but still can't figure it out? Power steering column if that matters?
Logged
RUSTY Cuda
Sr. Member
One big step foward!
Re: How do you remove steering coupler?
Reply #1 on:
June 21, 2009 - 11:03:25 PM »
Should be a pin down near the bottom to punch out & then work the coupler up, sometimes easier said than done!
Rich.
Logged
leithal
Jr. Member
Reply #2 on:
June 22, 2009 - 10:01:41 AM »
Did this a couple of weeks ago. Just use a little penetrating lube and knock out the roll pin...I think I used a 1/4 punch and about 3 wacks with 2 1/2 lbs.
Logged
LAA66
Sr. Member
Reply #3 on:
June 22, 2009 - 11:08:20 AM »
Sometimes the roll pin can be tough to remove. All of the hammering doesn't do the steering box bearings any good either.
Another option is to remove the small pin and the retainer then pull the steering column back. The coupler guts will come out leaving the coupler in place. Having a helper in the car to reinstall the parts makes it easier.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
June 22, 2009 - 01:41:27 PM »
a tie rod pickle fork will pry up the coupler after the roll pin is removed
Logged
brads70
C-C.com Expert
Reply #5 on:
June 22, 2009 - 02:59:58 PM »
I mean how to you remove the coupler from the column? I have it off the steering box.
If that's what you mean about the split pin?
Logged
340SIX
Jr. Member
Reply #6 on:
June 22, 2009 - 03:24:52 PM »
There is a realy small pin that holds it on might have to clean it up some to find it
Logged
brads70
C-C.com Expert
Reply #7 on:
June 22, 2009 - 11:10:31 PM »
Oh Ok I'll look!
Thanks Brad
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #8 on:
June 23, 2009 - 03:10:48 AM »
yeah there is a tiny pin near the top of the coupler , I use a wrench & just pry it back rolling the end of an open end wrench in the end of the coupler
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #9 on:
June 23, 2009 - 03:11:54 AM »
make Sure you mark thew orientation of the coupler on thew shaft , if you put it on 180* out the steering wheel will be upside down
Logged
chaps70rt
Full Member
70 Challenger R/T Hardtop in Progress (Canada)
Reply #10 on:
June 29, 2009 - 12:55:53 PM »
Good point. This is something I forgot to do. YIKES!! I guess I will find out when it goes back in. Can this not be corrected by disconnecting the coupling from the steering box and rotating it?
Thanks ... CHAPS70RT
Logged
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Chryco Psycho
Administrator
C-C.com Guru
Reply #11 on:
June 29, 2009 - 12:58:12 PM »
no , there is only 1 master spline , the coupler only goes on one way , some steering shafts have a small hole drilled into them , thhis is on the same side as the small retainer pin near the top of the coupler
Logged
chaps70rt
Full Member
Reply #12 on:
June 30, 2009 - 11:21:51 PM »
Thanks CP ....... I will check mine before re-installing. Just got my column rebuilt and am about to reinstall in place. Had a heck of a time getting my coupling pin off of the shaft (polished piece that goes inside the coupler). The coupling kit came with a replacement, so I figured I should punch it out and install new. It was extremely stubborn, then the new one simply pushed straight through?
Logged
440 - 4BBL - Shaker
brads70
C-C.com Expert
Reply #13 on:
June 30, 2009 - 11:30:18 PM »
Thanks AGAIN
CP I got it out!
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #14 on:
July 01, 2009 - 03:45:16 AM »
Congrats Brad
the solid pin can be a tough one to get out , I rarely replace it unless the shoes are loose on the cross pin
Logged
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
